  • 2.3L (N/A & Turbo) Tech
installing distributor
  • Thread starter Thread starter 89' RICE COOKER
  • Start date Start date May 22, 2004
89' RICE COOKER
325
Po-town Oregon
May 22, 2004
  • May 22, 2004
im currently in the mix of putting together my motor. (started as just a block and head.) im having a problem installing my distributor. in my haynes book it says to line up the lines that was sopposed to be made on the block and dis. when the removal was done. well i dont have any lines on the block or the dis. I dont know where to start, so i figured here would be my best bet.
Thanx in advance guys.
89' RICE COOKER
325
Po-town Oregon
May 23, 2004
  • May 23, 2004
nine reveiws, 8hours later. nobody knows?
Shopteach
20+ Year Stangneter
Apr 11, 2003
48
Berryton, KS
May 23, 2004
  • May 23, 2004
This is how I do it. Put the timing mark on 10 degrees BDTC. Find the #1 terminal on the distributor cap and drop the distributor in with the rotor pointing at #1. When you get ready to start the engine, remove the #1 spark plug and lay against a good ground such as the block, turn the ignition on and slowly rotate the distributor opposite the normal direction of rotation. When the get a spark at the plug, lock the distributor down and the engine should start. Most of the time I don't even have to move the distributor when checking it with a timing light as it is usually right on the mark.
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
