Installing gauges
smokinit2
22
Miami, Fla.
1992 5.0 I have 2" FR gauges oil,water, temp, volts.I'm gonna place them with a face plate that will hold the radio over the three gauges my question being.Is there a spot on the firewall to pass the wires somewhere? Do I have to drill a hole, whats the best spot, any new ideas,thanks.
Do you have a small tool that looks like a hook? Take a sharp punch tool, and puncture the steering column cover boot to pass your wires through.
Take the hook, from inside the car, and push it through the hole you made with the punch tool. Go to the engine bay: Put your sender wires (if they are electrical) inside the hook. Go back to the interior and pull on the hook tool to pass your wires through the rubber.
This method minimizes the size of the hole required for passing wires between the engine and interior compartments.
I assumed electrical gauges.....
Water temp gauge ( has wire with sensor to connect to engine),oil pressure gauge(has plastic tubing to connect to engine) ,but I'll check that out thanks.
