  • 1994 - 1995 Specific Tech
installing headers
  • Thread starter Thread starter jtb19nh
  • Start date Start date Dec 23, 2005
1 of 2 Next Last
jtb19nh
156
Dec 23, 2005
  • Dec 23, 2005
Im getting ready to install my bbk shorty headers and my o/r x pipe any tips or tricks i should be aware of to make the job go smoothly
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Dec 23, 2005
  • Dec 23, 2005
Patience, beer (if your legal), friends (more hands), AFLAC card and more beer if you get in a bind.
There really are no tricks. It's bascially nuts and bolts and time consuming wrenching.
95cobraguy
637
11
Concord, NC by way of LI, NY
Dec 23, 2005
  • Dec 23, 2005
what i always did when installing my mac headers was drill one of the end bolt holes a little bigger so its easier to get them all started. and the drivers front bolt behind the a/c bracket is a ****.
bill302
2,131
alabama,gadsden
Dec 23, 2005
  • Dec 23, 2005
passenger side is not too difficult but the egr tube to header tube is a pain. on the drivers side you will have to remove 1 brake line from master cylinder when i installed mine i removed the line at the master cylinder and pushed it carefully out of the way after install i reconected it i didnt even have to bleed brake system they worked great. i would recomend getting some type of HEX HEAD BOLT WITH 3/16 RECESSED ALLEN HEAD i used the bolts that came with my headers i had no problems with the bolts but in some of the tight places it would have been easier to use allen wrench to tighten. and torque to 16-32 lft.lbs.
ej95cobra
82
Southeastern PA
Dec 23, 2005
  • Dec 23, 2005
I brought the driver's side up from below when I installed the BBK shorties;simply disconnect the steering linkage to get it out of the way. It went up really easy when I finally figured it out.
drakesdad
961
Oregon OHIO
Dec 23, 2005
  • Dec 23, 2005
If you have BBK you are golden. I learned my lesson with cheap headers. We had to bore the holes out to attach to heads and then exhaust would not bolt up correct on passenger side. I ordered BBK shorties and they went on without a hitch. You have play with the drivers side to get it in but not a rough job at all.
84convertablegt
589
Columbus, OH
Dec 23, 2005
  • Dec 23, 2005
hummm, i had no problems at all. i installed flowtech shorties and i went from the top on both sides. I did not have to remove steering linkage or brake lines, just had to finagle them in there. the problem comes with bolting them up. u need small wrenches, forget about sockets. also, make sure you start and tighten first any header bolts where the clearance besides the tube is close, otherwise you cant get the bolts in. This is hard to describe, and unless youve done headers before you wont know what i mean. basically unless the tubes are notched where the bolts go, it can be a pain. i had one bolt on the pass. side like this and 1 or 2 on the drivers side. the offroad pipe was easy as well but getting it in the stock brackets was the hard part under the car.
jtb19nh
156
Dec 23, 2005
  • Dec 23, 2005
how hard to disconnect the steering linkage what do i have to do to disconnect it
bill302
2,131
alabama,gadsden
Dec 23, 2005
  • Dec 23, 2005
i believe removing the steering shaft would be alot more difficult. than removing brake line. i have never removed the steering shaft from a mustang but i removed one from a sierra it had one bolt at the steering box and a bolt half way up shaft after both bolts were removed the shaft slid up out of steering box connection and then pulled out very simple. i believe all steering shafts are similar.
drakesdad
961
Oregon OHIO
Dec 23, 2005
#10
  • Dec 23, 2005
  • #10
Amen On The Shorty Wrenches, A Must.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Dec 23, 2005
#11
  • Dec 23, 2005
  • #11
You mean "a lot more simple, right?"
Because the shaft is a piece of cake to remove....seriously.
Scott
bill302
2,131
alabama,gadsden
Dec 24, 2005
#12
  • Dec 24, 2005
  • #12
Scott
remove one fitting at the end of brakeline where they enter the master cylinder and push line out of way remove then install header reconnect line and drive
(versus)
jack car up get under it remove approx. 2 bolts slide steering shaft up and out remove and install header reinstall approx. 2 bolts with steering shaft let car down off jack and drive.
everyone has there own way they like to do things, i hate jacking up a car and getting under it
bimmertech
1,123
merriam, ks
Dec 24, 2005
#13
  • Dec 24, 2005
  • #13
(versus)
he's gotta jack the car up to take off the mid-pipe anyways. if you remove a brake line you have to bleed your brakes afterwards.
these are shorties though, he should not have to do any of that. put the drivers side in from the bottom, and the pass side in from the top.
bill302
2,131
alabama,gadsden
Dec 24, 2005
#14
  • Dec 24, 2005
  • #14
i installed mine and never jacked up the car and didn't have to bleed brakes you can remove the line at the master cylinder reconnect without getting air in system or i know i did it. i'll start a new thread about this subject.i could have just been lucky.
GRGT1994
1,034
#15
  • Dec 24, 2005
  • #15
Do yourself a favor and get some longer bolts, preferably the locking kind, but in any case make sure you use something longer than the 3/4" that come with the BBK headers. I got some 1" Breslin locking bolts (SummitRacing.com) and have had no problems since.
Seriously, after you go through the pain of pulling and installing headers, the last thing you want to deal with is tightening those damn things and toying with them. Do it right from the start.
Good luck.
jtb19nh
156
Dec 26, 2005
#16
  • Dec 26, 2005
  • #16
how the **** did you guys get the drivers side front bolt out the one behind the ac. i got all the others loose except for that one. also does anyone know the size wrench for the egr tube?
bard
Frisco, Tx
Dec 26, 2005
#17
  • Dec 26, 2005
  • #17
Small cresent opened up all the way fit the EGR nut. I don't recall any major issues other than being thankful that I had locking bolts.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Dec 26, 2005
#18
  • Dec 26, 2005
  • #18
if you are installing shorty headers, there is no need to disconnect the steering linkage. with longtubes though, its a totally different story. the shorty headers should slip right in with very little problem.
jtb19nh
156
Dec 26, 2005
#19
  • Dec 26, 2005
  • #19
what did you guys use to get the drivers side front bolt out. i cant get a socket in there and im not sure if i can even get a wrench in there? aslo when installing the new ones do i just put the gaskets on and bolt up or do i need to use any rtv or anything?
legalize420
1,541
South Florida
Dec 26, 2005
#20
  • Dec 26, 2005
  • #20
7/16 wrench. major PITA. gaskets go on dry.
1 of 2 Next Last
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 23, 2026
nickyb
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
W
Dipstick
  • wccurtis1963
  • Jun 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
Willybill32
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
J
4 bank eliminator chip
  • JJ's90fox
  • Feb 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2026
AeroCoupe
