  • 1994 - 1995 Specific Tech
Installing Morroso wheel studs?
  • Thread starter Thread starter badingle
  • Start date Start date Apr 24, 2005
badingle
127
Portage, Michigan
Apr 24, 2005
  • Apr 24, 2005
Are these things tighter than stock or what!?! They dont want to draw in. I know I have the right ones. I cant get a hold of a 36mm socket to get the hub off to press them in either.
Any suggestions?
-Andy
badingle
127
Portage, Michigan
Apr 24, 2005
  • Apr 24, 2005
anyone? help?
JJ95GTID
1,141
Phoenix, AZ
Apr 24, 2005
  • Apr 24, 2005
Drill?
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 24, 2005
  • Apr 24, 2005
You can buy an acorn nut from an autoparts store for less than a dollar. Put the stud in the back of the axle. Put a little big of grease on the top of the acorn nut, leave the wheel off, and screw it on backwards. Turn the nut slowly with a wrench, and it will pull the stud in slowly.
Kurt
badingle
127
Portage, Michigan
Apr 24, 2005
  • Apr 24, 2005
Kurt
tried that and stripped the threads in the nut.
badingle
127
Portage, Michigan
Apr 27, 2005
  • Apr 27, 2005
bump
Killercanary
The car that set the bar.
Altoona, PA
Apr 27, 2005
  • Apr 27, 2005
Andy, which studs do you have? I just installed moroso part number 46185 up front and they went in slick as hell. I did have the complete spindle off the car though at the time though (I was doing my K member). I braced the hub around the wheel stud and then hit it out with a hammer. To install them I just reversed the process. I put the stud in as far as I could and then used a brass punch and a hammer to drive them in... it was SIMPLE and I had it done in no more than 15-20 minutes. I hope this helps. P.S.- I sprayed the studs with PB blaster before I tried knocking them out.
Killercanary
Altoona, PA
Apr 27, 2005
  • Apr 27, 2005
BTW- DO NOT TAKE THE HUB NUT OFF!!! It takes like 250ft/lbs of torque to reinstall it and it is a permanently sealed bearing in there.
badingle
127
Portage, Michigan
Apr 27, 2005
  • Apr 27, 2005
I have the 46185's also. I already took the hubs off, too late for that one. Opps... I tried putting them in a press and they are still very very very tight. I got 2 pressed in and thought i was going to break it so i stopped.
I dunno what to do now.
Killercanary
Altoona, PA
Apr 27, 2005
#10
  • Apr 27, 2005
  • #10
I have NO idea why you are having such issues. What knurl size was marked on the package? Try freezing the studs and heating the hub a little before you try again, it should help.
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
A
79 mustang pace car spoiler.
  • Anglosaxon83
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2026
Anglosaxon83
A
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
