I"m thinking about installing my 3.73's myself, does anyone have any good tech articles that could walk me through it?
yes new speedo gear is required in order for the odometer and speedo to read right but thats the easy part. You are going to need a new pack of carrier shims ( get the ones with the .05-.10 kit) to get the right back lash and a pack of pinion shims in order set the correct pinion depth, new pinion seal, new crush sleeve or sleeves as it seems i always end up messing up atleast once on pinion depth lol and a backlash dial guage in order to get the correct setting on the gears. And i would also recommend replacing the pinion bearings(you might have to as they are impossible to get off without destroying them, sometimes you can re-use the outter bearing but the inner is for sure a goner) and i would recommend a new set of carrier bearings and races to be safejmd2914 said:cool thanks, im not even sure what all i have to do, just swap the ring and pinoin along with a new speedo gear? cuz i already have track lock.
