Installing new EFI harness
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
So my current 86 has been converted to MAF but not sure about the quality of the job and there are issues with the wiring currently (O2 sensor wiring not working and such)...
So I found an 89 harness (from computer to injectors, to O2 -> everything). I was going to ask how I should clean it up and check for issues before installing. I don't want to replace one issue with another. So here's what I'm going to do and tell me if I'm wrong lol
1) Remove the old plastic wrap and tape, 2) clean the wires and connectors with brake cleaner, 3) check the wires for cracks or dryness and replace if needed. 4) check for resistance (a lot of work but will know if it's perfect or not) and fix issues if any. 5) re-tape with black tape and add new black wire protector things.
Also, I'm bored waiting for my servers to transfer files... :nice:
I don't know that I'd actually spend all that time unwrapping the entire harness, you might have luck with checking resistance and continuity end to end without tearing it apart and then just fixing any problem areas. I also would not use brake cleaner on it.
Been there and done that... many times...the squirrels in your server to run faster... There is a trap door in the back that you open up to feed them peanuts and vitamins....
The harness removal and resinstallation is like wrestling with a python. Use some mineral spirits to clean the harness, watch for bare wires where the wires exit the main harness. Check points would be the Baro sensor, MAF sensor and TFI wiring.
A good electrical contact cleaner will do wonders. Stay far away from brake cleaner. You can dissect the harness are rewrap it, but it may not be necessary. Look for areas where the wrap was burned, melted, pinched, etc., then go from there.
