Installing new Lifter questions
  • Thread starter Thread starter JCB-69CJ
  • Start date Start date Mar 20, 2010
J
JCB-69CJ
  • Mar 20, 2010
I am in the process of replacing my intake manifold gasket and was wondering what it would take to replace the lifters while I am in there. Is it a simple process of pulling the old ones out and putting new ones in? I am running a 428cj and the ford manuals make it appear as a simple switch. Would I need to replace pushrods or do any adjustments? Would I need to know the specific cam installed? Thanks for all your help.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Mar 20, 2010
  • Mar 20, 2010
What's wrong with the lifters you have?
J
JCB-69CJ
  • Mar 20, 2010
When the engine is cold I can hear a slight tapping sound coming from cyl number 1 or 2 area. Its hard to tell which one. The noise seems to get lower after the engine gets up to operating temp. I am assuming that this is a lifter tap. I will be getting the manifold off soon and pull those lifters. I don't know how to tell if its bad or not, so the thought was just to replace them all.
D
D.Hearne
11,730
south louisiana
Mar 21, 2010
  • Mar 21, 2010
I'd leave em alone. If they get loud, then think about replacing them. If it's got adjustable rockers, you can tighten them up a bit. Problem is with the FE adjustable rockers is they have an interference fit thread and the threads can get worn in from frequent adjustments, at that point they need to be replaced.
D
D.Hearne
11,730
south louisiana
Mar 21, 2010
  • Mar 21, 2010
And have fun with that 95 lb intake. You really should use an engine hoist to set it back in place. It's damned near impossible to do without disturbing the gaskets and trying to stab the bypass hose at the same time just by lifting it without a hoist.
2+2GT
3,333
10
79
Mar 21, 2010
  • Mar 21, 2010
I agree, leave them alone, or at most, adjust them. Replacing them may not even solve the problem.
J
JCB-69CJ
  • Mar 21, 2010
Thanks I will leave the lifters as they are, its a low tap at this time. BTW I did buy a chain hoist to get that manifold out and it worked like a dream. I knew it was at least 75lbs and getting it back in without a gasket leak will be nearly impossible.
D
D.Hearne
11,730
south louisiana
Mar 21, 2010
  • Mar 21, 2010
Smart man ! Smarter than I was 25 years ago when I fought that battle. Standin on the inner fenders while lowerin that first CJ iron intake onto the 390 in a 67 Stang. Bought me an aluminum PI intake first chance I got. Lost 50 somethin pounds with that swap.
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
