Simply, where do I hook up the fuel line going from the fuel solonoid? I have a BBK adjustable fuel press. regulator. I heard you can hook it up to the schredder valve, however you spell it, not sure where that is though. Any help is appriciated.
You hook it to the shrader valve. You have to remove the stock fitting and buy the needed fittings to make it work. I think its 1/16" for the shrader valve and the nitrous line should be 4an. Just be VERY careful tightening those brass fittings, they can snap easily. Use a little thread sealent on the shrader fitting but I don't think the an fitting uses any sealent.
hardware stores prob only go to 1/8 fittings. you will have to go to a speed shop in your town or order it from autometer, NX, NOS/Holley, summit, ect.....
