Installing Race BUllets with clamps
savegoodautonfg
1,085
The reason i dont want to get them welded is because i want to make sure i like them on my car then maybe ill get them welded.
question are:
My h-pipe is 2.5 inlet diameter. then you have the flanges then the 2 pipes then the mufflers.
The 2 short pipes after the flanges i believe are 2.25" OD. (anyone know if i'm right?)
Then i would need a http://store.summitracing.com/partd...923429+4294820497+4294846842+115&autoview=sku
The clamp to use for that would be http://store.summitracing.com/partd...&N=700+4294923429+4294919986+115&autoview=sku
Would this all work or what?
Trying to figure this all out.
i've seen the exact same reducer your talking about at napa, auto zone, checker, chiefs, kragens, for probably the same price and you wouldn't have to pay for shipping?
since you said you don't want to weld anything up until you decidewhat you want to do so why buy 4 exhaust clamps from summit @ $9 each when you can buy some u type muffler clamps for $2 a piece at most auto parts stores or muffler shop that will serve the same purpose?
i thought those other band type clamps are better, but what you saying it just use 2 clamps where the reducer is? one for the 2.25" pipe and one for the 2.5" muffler part?
You don't wanna use a reducer, you want it to slip over, so that the inner diameter stays 2.5 inches. I went to Autozone and got some 18'' 2.5 pipe that was flaired at one end to slip over.
IF I GET "some 18'' 2.5 pipe that was flaired" your saying that will slip over the dynomax race bullets?? well what about the flange part?
also how come your saying not to use a reducer? why not?
If you use a reducer...something that slips "inside" the pipe, you're bottlenecking the ehxaust. You wanna keep it at 2.5 INNER DIAMETER all throughout. As for slipping over, measure and make sure whether the Bullets inlet is 2.5 inner or outer diameter...i don't recall but it might be big enough to slip over a 2.5 pipe itself, in which case you wouldn't need the flaired end.
On my setup i had to use a ball flange, which i cut off of an old H pipe i had laying around. If you can't get ahold of those, you might have to check out an exhaust shop...some of them can make the flairs for you.
well the flange pipe is 2.25" OD so either way its already not 2.5" ID throughout.
the flange pipe will be going into the dynomax race bullets. dynomax race bullet is 2.5" ID/OD and the flange is 2.25" OD.
You understand what i'm saying?
Ok....starting with the mufflers themselves...
They SHOULD be 2 5/8 inch ID on both inlet and outlet (so that they slip over 2.5 without bottle necking)....that is if you bought 2.5 inch mufflers and not 2.25. Remember that stock on a Mustang is 2.25 (pretty sure, it's been a LONG time since i even seen stock exhaust..lol) so if you maybe ordered them specifically for your car, maybe you ended up with 2.25s? If they're 2.5 ID, then they're probably meant to be slipped over 2.25 exhaust. Then you have 2 options....either weld a pipe straight to it so that it doesn't bottleneck, or have it flaired out by a muffler shop so it'll slip over a 2.5 pipe.
Basically to sum it up, if i were you i would make sure that you don't go down to 2.25 anywhere on the exhaust....if that means you have to return them or something....or have them flaired out...whatever you've gotta do. But, that's just me. It sounds like you just plain have the wrong mufflers....i don't know why you'd end up with 2.25 OD...that's smaller than stock.
Well the intermediate pipes the stock ones on like maremont.com are 2.25". If you go to summit racing they have the 2.5" ones from dynomax. so if my intermediate pipes that are on now are not 2.5" then i will get the dynomax ones that are 2.5" and bolt on the new intermediate pipes.
For the intermediate pipes all i have to do is unbolt the flange and put the new flange and intermediate pipe in and put a gasket between them? or if i'm wrong how does that work?
does that sound right?
Are they ball flanges? If so then you don't need a gasket....if they have 3 bolts in a triangular pattern then that's the one you'll need a gasket with.
Like someone else said, you don't need to buy those from Summit, go to Autozone or Pep Boys or just about any auto parts store and they'll have those pipes, probably for cheaper. Take a tape measure with you just in case, but most of the time they're marked on the pipe what inner and outer diameter they are. You can even take a muffler with you and figure it out there so you're not doing it in your head.
Also remember that one side is going to need to be longer than the other, because of how the H or X pipe comes back uneven. You might wanna take your other mufflers and measure how long the pipe is from the H/X to the muffler and then go with that length on each side for the Bullets.
my dad is the manager at an auto parts store.. i ordered for wednesday. both 2.5" intermediate pipes, exhaust flanges triangular ones, 2 mufflers.
the intermediate pipes are 2.5 OD and my summit h-pipe is 2.5 ID.
My question is on Dynomax website, maremont website they dont show on the diagram of the exhaust system for my car that you need a gasket.
i dont see how i would'nt need a gasket?
that would of been the first person i would have asked.
I did, but it's an auto parts/ custom parts store. hes the manager that knows everything about custom parts/ aftermarket accessories. he told me what he thought but i wanted to make sure with all of you guys.
There is a gasket that goes between the h-pipe flange and the intermediate pipe, right?
