  • SN95 4.6L Mustang Tech
Installing Rear Control Arms
  • Thread starter Thread starter 03Sleeper
  • Start date Start date Mar 2, 2004
03Sleeper
464
Fordville,USA
Mar 2, 2004
  • Mar 2, 2004
Hey All,
I've got a set of Upper and lower control arms on the way I was wondering if anyone here has installed them and if they were hard to do?
Seeing's how I did the springs in my car would this be somthing I could do in the Garage with some power tools and Jack stands and my trusty Floor jack!
LS2 KLR
452
Houston, TX
Mar 2, 2004
  • Mar 2, 2004
I just installed some a month or two ago. The uppers are very easy and the lowers aren't bad either. I did them with just basic tools. The instructions are pretty straight forward.
Roush97
1,006
Greencastle,Pa
Mar 2, 2004
  • Mar 2, 2004
since you did your springs you shouldnt have any problem installed them. worst part is getting the bushing out of the upper control arm mounts. other than that you'll have no problem
Slider
729
Gainesville, FL
Mar 2, 2004
  • Mar 2, 2004
Yeah, it is all easy except for the bushing on the differential housing. It will take most of your time to do this part.
I just dropped the whole thing since I did both sets and installed gears at the same time. I dropped the whole thing in about an hour using my custom made axle support. It was just some lumber pieces that I had around that I screwed together to cradle the housing. I just bolted it to my floor jack. It really made the job easy.
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
R
Suspension Lower control arms needed
  • racer_dave
  • Feb 9, 2026
1974 - 1978 Mustang II Talk & Tech Feb 20, 2026
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
