Installing Speedo Carrier
  • Thread starter Thread starter ricer-roni
  • Start date Start date Sep 4, 2004
ricer-roni
69
  • Sep 4, 2004
Well i am about to install a set of 3.90 gears into my 93 GT, and i have the 6 tooth drive gear, and 19tooth pink speedo gear for speedo corrections. I know the speedo gear is a simple install, but how about the drive gear. Do i have to take apart the tailshaft to get the new drive gear in there, or is it a simple out and in like the speedo gear. Thanks.
FrdMustangCpe
493
Sin City, NV
Sep 4, 2004
  • Sep 4, 2004
i would try looking up tech articles. try here, 50tech.com, i dont think 50resto has one...thats if nobody here knows.
good luck
D
dude5l
201
Grande Prairie, Alberta , Canada
Sep 4, 2004
  • Sep 4, 2004
The tailshaft housing needs to come off. You will have to remove your shifter as well and drive out the roll pin that holds the shift block on the shift rail of the tranny.
FrdMustangCpe
493
Sin City, NV
Sep 4, 2004
  • Sep 4, 2004
souds like fun...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 4, 2004
  • Sep 4, 2004
Check to see if there is a speedometer shop in your area. If there is, ask about the Stewart-Warner speedometer gearbox. I believe it is either a 777 Series Drive Joint Kits and Parts or 666 Series Drive Joint Kits and Parts. It is a small gear box that fits between the speedo pickup gear on the transmission and the speedometer. It has quick change gears that allow you to choose almost any tire size and rear end gear ratio you want. This will allow you to get the accuracy with within 2%-3% or less. The drawback is that it isn't cheap.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
