BigChiefSmokem said:
Make sure they're Adjusted right??? Um, you gonna have to be a bit more specific with what the heck you're talking about... BTW I wen to Pep Boys and picked up some spring fluid to go along with my headlamp fluid, which was low.
Oh, specifics hmmm ok:
*ahem*
Removal procedure:
1. Loosen the rear wheel lug nuts, raise the vehicle and support it securely on Jackstands. Remove the
rear wheels.
2. Remove the upper shock absorber stem nut, washer and grommet (save these pieces, they will be
reused). If the stem turns use locking pliers or very small open-end wrench to keep it from turning.
3. Remove the lower shock-mounting bolt. Remove the shock.
4. Remove the factory lower shock mounts.
5. Using a spring compressor, remove the factory coil spring.
Coil-over assembly:
1. Remove the lower rubber shock eye bushing from the shock absorber.
2. Install the o-ring into the threaded sleeve (Lakewood and Koni shocks only, Monroe GP shocks do
not use the o-ring.)
Note: For Koni and Monroe GP shocks, the steel dust cover must be cut off. Koni shocks also require that the
service nut be turned or ground down to 1.68” in diameter.
3. Install the aluminum-bronze shock eye bushing by holding them in place and sliding the safety sleeve
over the shock absorber body and bushings. (Note: The holes in the expanded end of the safety
sleeve should line up with the holes in the bushings.)
4. Slide threaded sleeve should line up with the holes in the bushings.
5. Thread on the adjusting ring and run it all the way down on the threaded sleeve. (Note: The shoulder
on the adjusting nut faces upward.)
6. With the shock absorber fully extended, install the new coil spring, hat, and 2” diameter rubber
grommet provided.
Installation (Note: It maybe necessary to remove the quad shock for adequate spring clearance.):
1. With the lower shock mount removed; Use a ½” drill to pin up the square hole in the axle directly
above the bolt hole for that factory shock mount. Install the new lower shock mount with the
hardware provided. Note: 5/16” thick spacer goes on the top stud between the mount and axle.
2. Install the coil-over assembly by positioning it in place and inserting the shoulder bolt through the
lower mount, safety sleeve, and aluminum-bronze bushings. (Note: Be careful not to over tighten
the 3/8” lock nut.)
3. Insert the shock absorber stem through the mount in the body by placing a jack under the axle and
slowly raising it (make sure to center the stem in the mounting hole). From inside the car, install the
factory grommet, washer and stem nut. Tighten the stem nut securely.
4. With the axle unsupported, thread the adjusting ring upward approximately 2-1/2 inches as an initial
setting.
Shouldve got the fluid at autozone .99 cent special
