I have a JL audio power wedge system i bought for my car and they are 8 ohm and require 125W RMS each. When i look for amps i never see a 8 ohm measurement of RMS why?? What do i need to get my speakers to 4ohm or to get a 8 ohm amp?
I think this was just a typo, but so as not to confuse him... 2 x 8ohm speakers wired in parallel will have a net resistance of 4ohms.
Any amp will work... it's just that some will be louder than others. Some amps are capable of running bridged into a 2ohm load. Those amps will put out WAY more power if wired to a 2 ohm load vs a 4 ohm load (in theory twice as much power).
Use these wiring diagrams. Pick out a setup that looks like yours. Sounds to me like you have "2 subwoofers"; "Single Voice Coil - 8 ohms". From that diagram you will be able to run your amp at 4 ohm, but if your speakers were 4 ohm you could run it at 2 ohms.
if your talking 125 watts RMS then you should look for a amp that states a number closer to 500-700 peak watts at 4 ohms. What is the peak watts for your speakers? Look for an amp that does that added up.
Sorry doing too many things at once. Yes a amp that puts out ~250 watts RMS (or continuous power) is what you would need. Just remember that all these number are at near full volume, so if you dont turn it up you could use a bigger amp, but you dont need it.
That sounds about right. But the subs don't require that much.. that is the most they can take. Minimum requirement would be something closer to 50watts each.
Don't read too far into the ratings... there is no stereo equipment police out there. A 500W amp made by a quality name-brand manufacturere will often put out more power than a 1000W cheapy amp. Same sort of thing goes for subwoofers. Name brand stuff is usually pretty close (except the older sony explode stuff which was absolute crap).
Very good point, most quality companies will sent a test sheet with the amp that shows what that exact amp will output. For example I have a kicker that says 500 watts mono into 2 ohms, but the test sheets says more like 750 watts. The info for the model is a minimum, meaning they wont ship it unless its above that ratting.
