Installing Traction Bars?
  • Thread starter Thread starter wickedmach1
  • Start date Start date Dec 30, 2005
W
wickedmach1
376
Austin, TX
Dec 30, 2005
  • Dec 30, 2005
Any secrets or do's or dont's when installing traction bars on a 1970 Mustang? I have the Shelby type. Can the car be on jack stands or does it have to be on the ground? Please help. Thanks
rbohm
6,698
550
204
tucson,az
Dec 30, 2005
  • Dec 30, 2005
the car can be on jack stands, just put the rear jack stands under the rear axle so the weight is on the springs. hold the spring mounting plate and have someone mark the front location. then bolt the spring end plate inplace and verify the location for the front mount. then teh front mount can be welded inplace.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Dec 31, 2005
  • Dec 31, 2005
Not familiar with the shelby type traction bar, but does it require removing the u-bolts from the existing perch?
If so, don't put the jack stands under the axle as the rear end will tend to lift off the springs and create a dangerous situation. I looked at the ones offered by Branda and couldn't quite tell for sure.
If you don't need to remove the spring perch, then all is cool with jacking. Either way you would want the weight of the axle on the stand before welding the front.
rbohm
6,698
550
204
tucson,az
Dec 31, 2005
  • Dec 31, 2005
i perhaps assumed too much. yes the u-bolts need to be unbolted to install the spring mount, but i usually assume that people will support the body, along with the rear end when they get to the point that they are ready to actually install everything. silly me
BigDaddyCee
1,404
Canada
Dec 31, 2005
  • Dec 31, 2005
The Shelby Under-rider traction bars have a square/rectangle plate that bolts/mounts to the bottom of the spring perch which makes it necessary to remove the nuts on the U-bolts. In my case I had to purchase slightly longer u-bolts because adding the traction bars made the old u-bolts unusable. For this phase I supported the frame. But it is agreed that when you go to weld the front plate of the traction bar to the frame rail you well want to have your suspension under load.
dennis112
1,561
36
79
Dec 31, 2005
  • Dec 31, 2005
Good point.
I will add that if new U bolts are needed, most NAPA stores have some in stock. You may have to buy the longer ones and shorten them as needed because not all lengths are available.
dennis112
1,561
36
79
Dec 31, 2005
  • Dec 31, 2005
No big deal, I just don't want a "possible" mechanical noob to get in big rush and not pay attention.
(Not calling you a noob, WickedMach1, just trying to cover all bases as some may be checking out this thread too.)
M
Looking for a passenger side AC Compressor mount
  • mustangTodd
  • Feb 10, 2026
Classic Mustang Specific Tech Aug 22, 2026
s_mi11er
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
W
Strange connector near fuse box
  • W4rl0ck
  • Sep 23, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 28, 2026
gkomo
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
