instrument lights - what voltage do they run at?
enferno
418
title says it all.
i have a 66 coupe. i'm considering converting from those dinky POS instrument lights and rigging some LED's in their place, possibly placing 2 per gauge. Benifits of this would be much brighter, less heat, and lasts a lot longer than conventional bulbs.
i need to know what voltage the instrument bulbs run at so i can determine what rating of LED's i need to buy etc.
thanks in advance!
TyMeFlAmE said:
I've been thinking about doing just that for the past week
well perhaps we could brainstorm on how to do this then.
my car is gutted as it it going to the paintshop on tuesday, so i can't test and see what voltage the instrument lights get.
if someone can just run out with a voltmeter and let me know, i can draw up some schematics and list what kind of LED's & resistors etc. are needed, as well as make a tutorial if what i have planned is successful.
The lights run on 12v's. But why build something when the bulbs, as pointed out, cost only a few bucks? I like projects too, but if you buy the bulbs you won't have to cut any wires, it's a quick change, and you're on to another project :D
LUCAFU1 said:
they sell leds with 6 bulbs for one plug so it gets really bright
No doubt, except the light is like that from a flashlight, one direction. I am not trying to say this won't work, just trying to point out that this is not going to be as easy as it seems. If it was, don't you think others would have already done it?
im assuming you HAVEN'T done it,so you dont know, but i HAVE done it it works just fine for me,maybe a little even better then the 40 year old bulbs that were in there
66HertzClone said:
One problem you are going to find is the LED's are directional, light out the front of the LED, not much to the sides.
There are two solutions I can think of. Either get LEDs with the widest viewing angle possible(which will knock down the mcd rating, unfortunately) or make one "frosted" with a little 600 grit paper.
You can also punch out the glass from old bulbs and replace it with an LED and resistor. That way there is no hardware modification and it is totally reversible. I don't know how well they work with a dimmer, though. My highway driving usually happens at night and I often have the instrument lights darn near turned off.
Edit: W00T! 3000 posts!
