Intake and underdrive pulleys
Steeda pullies are good ...and I would just get a K&N air filter instead of the CAI ...they won't give you additional gains over just the filter unless you get a new MAF sensor too ...basically they just look nicer
I just installed my JLT CAI this past weekend. I got a good deal on it (200 for the complete "kit"). I've noticed that it runs a little smoother and picks up just a little bit quicker, oh yeah, and it looks very nice too. I'm also hoping to pick up a few mpg's as well. But I wont be able to see those improvements for another couple of weeks, as the 'puter "re-configures" itself taking into account the recent addition of the h-pipe, catback and CAI.
What??
We've proven that a drop-in k&N is useless and a CAI can add some decent HP. Where are your numbers?
http://www.stangpro.com/html/articles/tunableinduction.htm
Steeda pulleys are the only ones to use with the oil pump issues the cars have.
For CAI, DeMolet makes the most power and the JLT is very nice as it come be had painted the same as the car. The key is to avoid the metal systems.
StangPro said:
What??
Yep...the first mod I did my GT, a K&N FIPK-II, gave quite impressive results:
http://home.golden.net/~trinity/Dyno/kndyno.jpg
:banana:
I feel okay with the March piggy backs too since they preserve the factory damper. Got okay gains from these too:
http://home.golden.net/~trinity/Dyno/pulleysdyno.jpg
(plot shows gains over stock; includes K&N intake...pulleys netted about 4.5 hp & 7.1 ft-lbs themselves)
StangPro said:
What??
i just did a demolet tunable inductions and noticed a nice gain above 4000 it seems to run alot smoother in the higher rpms and then installed the steeda pulleys a week later and also noticed a slight diffrence more from the intake then the pulleys.
:banana:
That's what I like to see, actual dyno proven gains.
I had the K&N FIPK on my 97 and it seemed to have in increase, mild or not, it was still an increase. If you add 5 here and 5 there, that adds up.
Steve777 said:
maybe I should say "noticeable" gains. They will be very minimal with just the CAI alone. Upgrading the mass air unit is the best way to get the full benefit of the cold air and I don't believe most CAI setups come with a new one
Oh Ok, I thought you ment just the MAF "sensor".
:banana:
When you tested the CAI on the Dyno, did they do a base run, then put on the CAI and do a tune to correct the a/f ?
Or did they do a base run, then a tune and then add the CAI and do another tune to make sure the a/f was the same for the before and after?
No, no tune. The car was dyno'd stock. The battery was then disconnected, the factory intake removed & the K&N installed. Battery reconnected, a couple of "miles" on the dyno to ensure all was good and to restore engine temp to about what it was before and the car re-run.
Oh OK cool, thanks. I was just wondering if there was any change in the a/f ratio after the CAI install. I was hoping to find an independent dyno test of a CAI that had the a/f corrected before and after the addition of a CAI to make sure that it wasn't just the CAI leaning the a/f, thus the increase in HP due to the leaner mixture. The EEC should be able to compensate for the difference anyway as you don't have the bend going into the fender that may disrupt the MAF readings. Thanks for the info :nice:
