intake done, vacuum leak?
mob
the guy who hits on his mom
Oct 3, 2003
2,566
136
104
Dallas, TX
Hey guys. As suspected i think I have a vacuum leak becaues the hoses werent put on 100%, im still going to have to do some things to it. But let me make sure.
I started the car up, idle awesome at like 700. I realised right away I had no power brakes, obviously a vacuum leak. Now when i started driving, it was bogging around everywhere, couldnt maintain it at one speed. Then I took it out on the road, i hit it, not to mess around, but to see what it would do in all the rpms. It didnt pull for crap! at all, slower then my moms 4cyl, at about 2krpm it backfired, 3krpm no more fuel and bogged, then check engine light flashed on, then it got fuel and kept going. I drove it to buy a timing light, it drives horribly, so rough, bogs randomly, cuts off fuel randomly, and engine light flashed a few times. Took it home, timing was way off of course as suspected. Put it at 14, and I changed the vacuum line to the tree but still isnt on the intake 100% and I can hear a hissing from the vacuum still. But atleast now I have ALITTLE power brakes, still get stiff when I push it down all the way, but its better then it was. I took it for a ride, after the timing it pulls now, pulls good, but still at about 2k rpm is backfires, 3k and up itll randomly cut off fuel bog engine light, and then it jump back again and bounce around. I hit it the first time after the timing, it pulled good in 1st, pulled good in second, then i hit 3rd fast, and at 4k rpm in 3rd it just bogged like it cut off fuel. Did a uturn, tried to hit it one more time, around 4k rpm it bogged again, then kept going and at 5krpm it just stoped going up and the rpms were bouncing at 5k. So i just slowed it down and took it easy after that, if I am stoped, and rev the car up same thing happens backfires, and at around 4k it stops reving. Cruising at about 55mph in 5th gear at about 1700rpm, the car is VERY rough, bounces around like its going over bumps. Is this a vacuum leak? Im not sure if a vacuum leak can cause all the problems, hopefully it can and its not anything else. Could it be spark plugs or something? Oh and when I adjusted the timing, i plugged the spout connecter back in when I turn the car off, thats ok right? Any help would be great, im gonna try and get that vacuum line to the vacuum tree fixed so there isnt a leak anymore.
fixed the vacuum leak, it boggs BAD anywhere under 2krpm in any gear, and after 3k it feels like fuel is IMMEDIATLY CUT OFF and engine light will flash really quick, i hit it in first and floored it real quick and let off, tires spun and it revved up to 4500 no problem, but it was for a split second, but when I shifted to 2nd and tried to go, like I said 3k rpm NOTHING. Is the car missing or pinging? Ive always heard those terms but never expierened it. Timing is at 14, should I put higher octane fuel in it then 87? Its running VERY LEAN, like sitting at idle with window down my eyes will start to teer up and I feel like im going to die with the fumes, I think thats lean? I also noticed when I installed the upper intake that the PCV vavle hose dosent really hook up to the lower intake anyway, like it slips in but its not held down in anyway, its really loose, i didnt think that was too safe, is there anyway that could be it? Should I take the lower intake off and retorque the lower intake with a torque wrench?
Oh and my 55MM t/b and egr are mated up to the 65MM explorer intake opening, would that cause a problem? Could it be one of the spark plug wires wasent pushed in all the way or a sparkplug is bad?
if its making your eyes water and tear up then its running rich. You probably still have a vacuum leak somewhere just not as bad. Get some Carb or throttle body cleaner and spray it around where the vacuum hoses connect up and around the gaskets and sensors that thread into the air passages, ie the ACT. If the idle increases in the when you spray a certain area then you have a small leak. Tighten up the bolts or make sure that the vacuum line is on there tight.
Where the PCV goes into the lower there should be a hole with a metal mesh screen in it and then a black rubber grommet on top of that. The grommet should fit snugly in the hole in the back of the intake and the PCV valve should fit snugly into the grommet. Then you take your hose from the valve to the intake. If the valve is loose in the grommet or the grommet is loose in the hole then it could be another area for a leak. I would probably go ahead and get a new grommet and screen and put them in if you get a chance. The screens hardly ever get changed cause most people don't know that they are there. And the grommets harden over time due to heat.
FWIW, I had the same type of problems with my 93 when I did my TFS intake swap. I was positive that I didn't have a vacuum leak cause I tightened everything and the hoses were all on good. I did the TB cleaner trick and found that I had a leak at the TB/EGR spacer gasket. Fixed that and the car idled great. Before it had a rough idle and it would want to die if I put it in gear and it ran REALLY rich.
Also if you have a code scanner I would scan for codes and see what is tripping the CEL. Jrichker has a write up on how to do it with a 12v test light if you don't have a scanner. Works just as good. You might also want to put a vacuum gauge on it and see what your vacuum is. Pretty cheap at Advance or Autozone.
Well if ur gett'n a check engine light dont u think it would be a good idea to run a diagnostic check? After that we can see what the computer comes up with and further diagnose.
alright thanks man, ill do the t/b check, and ill looking around the act and stuff, oh and i remember now, when I took off my act, it broke, like the white plastic part fell apart like powder, but it still plugs in, is tehre a way to get a new act sensor? could the sensor be messing it up and making it run rich? The car is over heating bad but it may be because I didnt fill the radiator up with coolant and no more coolant through the egr spacer isnt helping.
You can pick up a new ACT at the parts store.
Fill it up with coolant, check for vac leaks and pull some codes and go from there.
That is one of the nice things about doing just an intake swap instead of a whole H/C/I. It isn't as much to cover if you do have some probs especially if its the first time you have really torn into a car.
Theres a vaccuum tree on the firewall of the passenger strut tower brace that I pulled off when I was messing with my vaccuum lines and I almost didn't catch it. I think it's emissions bs but I dunno if that would affect how well it runs or not, but you may want to check there to be sure. Myn were a bitch to put on, but some vaseline, gojo, or anything to lubricate it would help it slip on easier.
yea got that back in, thanks!
Is it possible that you may have a pinched vacuum line rather than leak? I had a pinched one and when I took it for a test drive I had no power brakes. Maybe somethings pinched and it's not getting the vacuum it should?
No I dont think so, the line to the tree is brand new, and I have power brakes now. Im gonna go ahead and guess its the ACT sensor, running rich, not getting fuel, over heating, and check engine light flashing. Im gonna go ahead and buy a new one.
here is what it looks like plugged in
Here it is broken
Oh and heres a pic of everything installed just got it up
you did give the intake 24 hours to sit prior to start? Usually the RTV used on the ends of the block like a day to set up proplerly...plus you'll need to retorque after a few days of running at least once.
Yes the lower intake was put on about 2pm yesterday. All the gaskets and such sat over night, Only thing I did today was upper intake, I didnt use rtv on the upper to lower, and I did t/b and egr spacer. I didnt fire her up till about 5pm today. Once I get the car running right ill take off the upper intake and retorque the bolts.
alright guys ive narrowed it down to 2 things.
Ok so that small black plastic line coming from the connector behind the passenger side strut tower, and the FPR vacuum are connected to a split that connects to the intake. The split is very small I think that the FPR isnt getting enough vacuum, causing me to have no FPR and causing me to run full pressure at all times. Whitch may be reason for Running VERY rich, flooding at higher rpms, car reving byitself when braking, and bogging around all the time.
But when I was adjusting my timing to 14 i realised something. When I took out the spout connector, I adjusted the timing to 14 no problem. Then I put the spout connecter back in, look at the timing, and the balancer was jumping around from 10 to 20 like nothing EVERYTIME it came around, at IDLE. That cant be right. Could I have stabbed the distributor 180 off? Could my bogging and fuel problems be because its not firing at the right time? Would the car even run if the dizzy was 180 off? I can drive the car, its just VERY rough, and in the higher rpms its BAD but around 1700-2500 rpm I want to say it runs perfect.
