superhuaman
the computer controls the timing with the spout in...its not gonna be perfect at idle. if you raise the rpms to say 2k (where you think it runs good) then the advance should stabilize
mob said:alright guys ive narrowed it down to 2 things.
Ok so that small black plastic line coming from the connector behind the passenger side strut tower, and the FPR vacuum are connected to a split that connects to the intake. The split is very small I think that the FPR isnt getting enough vacuum, causing me to have no FPR and causing me to run full pressure at all times. Whitch may be reason for Running VERY rich, flooding at higher rpms, car reving byitself when braking, and bogging around all the time.
mob said:But when I was adjusting my timing to 14 i realised something. When I took out the spout connector, I adjusted the timing to 14 no problem. Then I put the spout connecter back in, look at the timing, and the balancer was jumping around from 10 to 20 like nothing EVERYTIME it came around, at IDLE. That cant be right. Could I have stabbed the distributor 180 off? Could my bogging and fuel problems be because its not firing at the right time? Would the car even run if the dizzy was 180 off? I can drive the car, its just VERY rough, and in the higher rpms its BAD but around 1700-2500 rpm I want to say it runs perfect.
Jaswir said:how long did it take for you to install it??
