Intake elbow adapter, universal?
I have an Edel elbow :(
It is smaller and I also think the path offered to air flow is more restrictive.
The restriction I talk about here has nothing to do with the smaller size btw.
Now ... put the two of em together :bang: :chair: :fuss:
Seems to me ... the TFS elbow (75mm & straighter path for air flow) is best and sooner or later ... I'll be a runnin one of em.
Grady
I have the PP elbow. It is a good piece. One hint for ya, plug in the IAC before you put the t/b on all the way flush with the elbow. It is a tight fit and you won't be able to plug it in after you tighten down all the bolts for the t/b.
I bought a PP elbow...if I didnt go into the purchase wanting to smooth it out/clean it up to match the explorer upper I would have been REALLY :mad: :bang:
The IAC would not even fit (not even if I put the t-body on first). I notched the area to clear. The casting was VERY rough. I spent several hours just to get it looking ok. I also dont like how the base that mounts to the upper looks. I spend several hours sanding it and getting it to match the uppers shape. Then I bolted it up and matched it to the intake while I smoothed the intake.
Got both the intake and elbow powdercoated silver metalic and damn it looks good now.
Get the tfs one and save the work.
