Intake Gasket Question
  • Thread starter Thread starter b1gp1mp1n247
  • Start date Start date Mar 23, 2004
b1gp1mp1n247
159
Pittsbrugh, PA
Mar 23, 2004
  • Mar 23, 2004
I bought a new adjustable fuel pressure regulator that i havent put on yet and i just replaced the upper intake gasket about a month ago and i was planning on putting on the new regulator tomorrow, i wanted to know since the gasket is so new do you think it could be re-used or should i buy another gasket? dont think im an idiot for not waiting to replace the gasket when i did the regulator! i bought the regulator the other day and wasnt planning on buying a new one. i just think my old one is messed up. thanks for the help!
schoonover_88
189
  • Mar 23, 2004
If there is nothing wrong with the gasket then use it, otherwise pitch it. When I sanded down my intake I used my 15 year old 165,000 mile gasket again and I have had no problems at all, but I did coat it completly in silicone. Good luck.
b1gp1mp1n247
159
Pittsbrugh, PA
Mar 23, 2004
  • Mar 23, 2004
thanks man. anyone else?
P
PRO50SC
1,012
Olney, Maryland
Mar 23, 2004
  • Mar 23, 2004
I would have a spare on stand by in case you tear the one you just put on. Nothin' worse than runnin' into a problem in the middle of the job and not havin' what you need at your fingertips. New gaskets not very $$$ anyway.
R
redterror302
895
Mertztown, PA or State College, PA
Mar 23, 2004
  • Mar 23, 2004
More than likely you will be able to reuse that gasket again, there is no coolant that goes through there, so you should be fine. Just take off the upper sometime during the day before the auto stores close, just incase you need to get one.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Mar 23, 2004
  • Mar 23, 2004
I think Bernie makes the best point - you won't know til you take it apart whether it will be serviceable again. Unless it's no hardship to run down a gasket at that time should you need one, the best thing is simply to buy a new one beforehand. And then, I'd put the new one in --- and if the old comes out in one piece, save it as your spare.
b1gp1mp1n247
159
Pittsbrugh, PA
Mar 24, 2004
  • Mar 24, 2004
thanks guys. im going to buy one just in case. as far as cleaning the lower intake, do i have to take it off the block to clean it??
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 24, 2004
  • Mar 24, 2004
That would be easiest....but then again...who ever see's the lower intake once the upper is back on. Unless you want to be meticulous about it?
xplo89gt
945
Boston, MA
Mar 24, 2004
  • Mar 24, 2004
I don't think you'll have a problem reusing that upper intake gasket. The upper intake is torqued so lightly that the gasket is probably in good shape. Again it is smart to have a spare. And what do you mean by cleaning the lower intake? Taking the lower intake off is making your job a hell of a lot longer. You will most likely need gaskets for that if you take it off, plus you need to drain coolant, and will need to use rtv on it. I wouldn't do it unless you are changing it.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Mar 24, 2004
#10
  • Mar 24, 2004
  • #10
Ditto xplo - he nailed it. Unless there's a good reason to do so or you're having problems with it, avoid removing the lower intake. Coolant has to be drained, cleaning the mating surfaces is a major pain, etc. To clean for the upper re-install, I usually stuff clean, lint free rags (not paper towels - they can tear off down in the port) in each of the ports so that debris won't enter, and then clean the surface. Use a shop vac to suck up as much as you can, especially when slowly removing the rags. No more than 10 ft-lbs on the upper to lower bolts; start with the two in the middle work your way out - first 5, then up to 10. Here's a tip - from the hardware store (or that big container with a million bolts in it we all have) get two bolts the same as the shorter upper intake bolts. Cut the heads off and slot that end. Screw them into the front and rear lower intake holes on the passenger side. They will act as dowels - they'll hold the gasket in place, and allow you to easily position the upper. ONce it's in place, put 2 of the longer bolts in and get them started, then remove your temporary dowels, and put the regular bolts in. Works great for upper, lower, valve covers and headers - especially if you're working by yourself.
Engine Re-torquing intake manifold bolts question
  • 91GTstroked
  • Feb 22, 2025
Fox 5.0 Mustang Tech Mar 1, 2025
Jarhead67
J
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
