intake gasket question
  • Thread starter Thread starter boosted68stang
  • Start date Start date Jan 26, 2010
boosted68stang
47
massachusetts
Jan 26, 2010
  • Jan 26, 2010
I Have a 302 thats stroked to a 347 and im planning on using my paxton supercharger to run around 5-8psi of boost and I was wondering if I needed a stronger intake manifold gasket over a oem one?
thanks
Rick 91GT
Mustang Master
95
99
PA
Jan 26, 2010
  • Jan 26, 2010
thanks
Nope, just make sure the intake is torqued down properly or it can lift under boost
On alum heads I use 20ftlbs, iron 24ftlbs and on boost applications I use a tiny bit of liquid teflon to help them from loosening up.
Busted Boosting
  • Jan 31, 2010
That is correct!
However, I am running these new VTS Heat Shield Gaskets on my Cobra and Lightning that virtually eliminated the heat soak to my new intercoolers. I think if you were able to lower the overall intake upper plenum and lower intake temperature by just using gaskets I think that it might give you a little more power by letting you add a little more timing.
Back in the day I know that they at least made a gasket for the upper and lower intake joint and I was running one on my 67mm turbo GT. It helped quite a bit with keeping my IAT's from increasing due to the heat soak of the upper intake from the high under hood temps of a turbo 302 not to mention the heat it was absorbing from the lower intake.
I dont know if they make them anymore as I didn't see them on their website but I am sure if you asked them and you had a few others that wanted a set that they would make them for you guys. That is what happened with my lightning anyway. I think they told me that I needed something like 5-10 people or 5-10 sets and they would make them. It has been a long time so I dont totally remember. It is at the very least worth looking into.
I will try to find the testing chart that I looked at before I got them to make the Lightning ones but no promises!
Here is their site link, I will try to round up their phone number from my receipts file of the mods on my car and truck, but again no promises.
VTS Racing
I think there is on of the Gasket performance charts here:
Velocity Turbo Systems, LLC
I will try to find the Big one that I looked at before and I will post it with the phone number when I find it.
Good luck and have fun! (watch for cops! lol)
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
New to this
  • 5.ohCS
  • Nov 1, 2026
2005 - 2014 S-197 Mustang -General/Talk- Nov 1, 2026
5.ohCS
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
