  • 1994 - 1995 Specific Tech
Intake Gaskets
  • Thread starter Thread starter Synned
  • Start date Start date Mar 13, 2007
Synned
took tubgirl on a date and got banned
Mar 31, 2005
991
Philly
Mar 13, 2007
  • Mar 13, 2007
Hey Guys
Just preparing for my gt40 intake swap...and I was just wondering which intake gasket kit I should get.
I have the lower which has the hole for internal emission, as well as the upper has the emissions port.
Which gasket kit should I get to block these ports? Are there specific explorer years?
Thanks guys
Joe
And it terms of the bolts...upper and lower bolts can be re-used?
parchisi
519
New Mexico
Mar 13, 2007
  • Mar 13, 2007
I've never heard of internal emissions. Anybody wanna fill me in Anyways synned, here's a bump for ya.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Mar 14, 2007
  • Mar 14, 2007
FPP-1250 summit part number for the felpro 1250 gasket set. i recomend using black RTV instead of the cork end pieces tho
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 14, 2007
  • Mar 14, 2007
If you get the Fel-Pro 1250 set, it comes with inserts that fit into the gaskets and block off the EGR passages from the heads to the lower intake.
69clark
731
Ravena, NY
Mar 14, 2007
  • Mar 14, 2007
You get one of these. This is what I run and I think Fel-Pro makes them. They are cheaper and don't come with the cork just gaskets.
Summit (ford) part #
FMS-M-9439-B302
FMS-M-9439-A302
Synned
Mar 31, 2005
991
Philly
Mar 14, 2007
  • Mar 14, 2007
Thanks guys, so this should take care of the head to intake port.
And in terms of the upper-lower gasket, it shouldn't really matter because nothing will be flowing up that hole anyway? So a gasket with that hole in the middle will be fine?
And I've never done an intake swap before...so just a thin coat of RTV sealant around the water ports?
Thanks again
Joe
Synned
Mar 31, 2005
991
Philly
Mar 14, 2007
  • Mar 14, 2007
FMS-M-9439-B302
FMS-M-9439-A302
But with that how do I block off the EGR port?
And BTW, would any local store stock these parts besides a dealership?
69clark
731
Ravena, NY
Mar 14, 2007
  • Mar 14, 2007
I think the first part number has the holes blocked off.
69clark
731
Ravena, NY
Mar 14, 2007
  • Mar 14, 2007
Is that what you mean?
blksn955.o
3,263
st.louis mo 314
Mar 14, 2007
#10
  • Mar 14, 2007
  • #10
you dont need to block it off unless your deleting it and even then there are other ways.
If your going to run a elbow that will block off the internal intake pass. Our external style egr will work with either internal or external egr intakes (since the elbow blocks off the ports).
If your running a fox t-body swap and want to delete the egr get an egr delete plate. I would just install the gaskets without blocking anything, that way if you want to go with a fox t-body swap you can keep your egr (no reall need to delete it unless its really busted). Since our eec with a blocked EGR untuned will prob. cause a ping/det. issue.
Synned
Mar 31, 2005
991
Philly
Mar 14, 2007
#11
  • Mar 14, 2007
  • #11
Okay, I get what your saying...so I don't even need to worry about which gasket set I get, as long as its for the right intake...but felpro makes the best gasket.
I do have the elbow adapter...its an ebay piece but seems to be pretty well made.
And about the old intake bolts...they will work fine?
Thanks again everyone
Joe
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
