Intake Help Quick!
BLKNGHT
12
okay, i just bought a trick flow track heat EFI intake for my 89. installation went smooth, got everything back in place and the car WILL NOT start. its turning over and sputtering a little like its about to start but it wont. its getting fuel, and spark so i dont know what could be wrong. i put the distributor back in and lined everything back up also. can anyone help me?
Are you sure you put the distributor back in correctly? It's easy to flub, no matter how many times you've done it. Bring the number 1 back to TDC on the compression stroke and check to make sure you've got it right.
Im going with the timings got to be off.. did you account for the distributors rotation, or a tooth off, as you insert it? It turns when you put it back in.. so lining up the lines you made isnt right.
Lets hope its that.. Need to back the dizzy up and then insert it so that the lines meet up. Then make sure the rotar is at one. Wire are all hooked up with the 351, or HO firing order. Make sure the car is grounded on the back of the head or block. After checking this, and car still not start, try turning the distributor, in place, as if you were going to retard or advance the timing..just in small increments..and see how that affects the start.
