Intake Install Issues
  • Thread starter Thread starter 5spd GT
  • Start date Start date Nov 6, 2011
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 6, 2011
  • Nov 6, 2011
I've made a couple runs at installing my ported Holley SMII on my AFR 185's and I keep running into coolant leaks around the ports and at the end seals. I have never had an issue installing other intakes, but his one continues to give me issues.
It also seems to me that it the intake is not sitting flush with the cylinder heads, meaning I need to have it shaved at an angle possibly. How do you guys measure for a nice tight true fit?
I have used both a regular 1262 and a 1262s-3 (steel core) intake gasket and very thick runs of "The Right Stuff" and Ultra Black on the end seals and around the coolant ports.
1. How do you keep the coolant IN the coolant ports?
2. How to measure and analyze whether the lower needs to be shaved?
A bonus question about timing, more because I am curious. If you set the timing at 0* for the #1 piston at TDC, then start the car and of course it dies. You then turn the distributor (NOT removing the spout), does it advance the timing?
capri debris
289
PA
Nov 6, 2011
  • Nov 6, 2011
What you're explaining usually occurs when the heads have been shaved and/or block has been decked. Anytime you remove material from the top of the block or the bottom of the heads, it will make the heads sit lower and closer together because of the V shape of the engine. This will make the intake too wide so it won't sit all the way down on the heads and cause alignment issues and leaks.
The fix to this is to shave the same amount of material off the mating surfaces of the intake... no need to change the angle on the mating surfaces. This will make the intake narrower and THEN it will sit correctly. Figuring out how much material has been removed is the question and it must be a total of what has been removed from the top of the block and bottom of the heads if both were shaved.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 6, 2011
  • Nov 6, 2011
The heads are new and I am using the same block as I did before and I did not have any problems with unshaved AFR 165's and Performer intake.
Thanks for the reply!
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Nov 6, 2011
  • Nov 6, 2011
My heads were shaved .015 and my block had been decked, .005 I think. The intake I am running was given to me by my father-n-law. He was running heads that had been shaved .080 and the intake had been shaved to match. I had issues getting my lower to seal and I was getting coolant in the exhaust.
I bought a thicker set of gaskets, Fel-pros (don't remember what part#). I was still getting coolant dripping from the exhaust. I was getting so frustrated that I threw my torque wrench across the garage. Luckily, a good friend of mine came by and lent me some good advice.
He works on forklifts and told me that anytime a head gasket blows and coolant gets into the exhaust, the mufflers fill up with coolant. He suggested that I take the car for a good spin and get the exhaust hot and blow all the coolant out. I followed his advice, and twenty minutes later I had no coolant coming out of the tailpipe. Looks like after the first gasket leak, I was just pissing away gaskets thinking that it was still leaking.
Maybe try sealing it up good and try giving it a spin around the block a few times. Maybe it will dry up.
Let us know, good luck with it!
J
junkyardwarrior
Well-Known Member
Jan 10, 2011
400
113
63
Nov 6, 2011
  • Nov 6, 2011
Almost sounds like the intake was originally set up for angle milled heads. When this is done the intake mating surfaces have to be milled at a little bit different angle to correct them misalignment. Happens often with circle track stuff especially.
If you set the timing at 0° spout out, it's going to be a turd...if it even runs at all. If you advanced it with the spout out, it's probably going to run a whole lot better. Doesn't matter if the spout is in or out if you're turning the distributor. The computer doesn't care. The spout should be out, however, to CHECK the timing with a timing light.
R
reldla1996
356
22
Dayton, Ohio
Nov 6, 2011
  • Nov 6, 2011
I'm running AFR 185 Comp (angle milled to increase compression) with the Holley Systemax intake (uncut), and used the Fel Pro 1262R, which is thicker (.090) and has larger ports (2.25x1.40) to help ensure the line up of the gasket with the head/intake ports. when I trial fit the 1262, they didn't line up quite right. I use a thin layer of the ultra black around the coolant passages, and a thick bead on the ends. If you turn the distributor, it will advance or retard the timing, depending on which way you turn it. Zero degrees is close enough for the car to run, not great, but run. Good luck, we have all been frustrated with something on our cars at some point!
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 6, 2011
  • Nov 6, 2011
The 1262R sounds interesting (thicker portion) to take up some slack.
Thanks for the timing issue, I understand the basics of it, but was chasing another issue. After reinstalling the intake after the initial leaking install, I can't get the car to maintain idle and it does not rev smoothly/fast, even after advancing the timing. I did rewire the 02 sensor wire that was chopped up by mice and replaced one 02 sensor as well. I also redid the valvetrain, but I know I got it right (done it a hundred times...lol).
TenorPlayinGuy
1,208
Canyon Country, Ca
Nov 6, 2011
  • Nov 6, 2011
Yeah, spout out, means you see the Base timing of the engine. Twisting the dizzy advances the timing no matter what. The computer merely advances the timing based on the program and the rpm of the engine based on certain parameters. I would of course set your base timing within 1-2 degress +/- of 10* though.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Engine Head gasket port matching plus head/intake port alignment
  • PonyGTrider
  • Dec 10, 2024
Fox 5.0 Mustang Tech Dec 12, 2024
PonyGTrider
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
