Me and a buddy just installed the edelbrock performer and 30lb injectors with new calibration tube. My problem is that after the install i get idle surges. The timing was check and it is fine, and the fuel pressure was bumped to 42lb. We swapped out all the old and cracked hoses and installed a new pcv valve, and thermostat. When im driving it runs fantastic but when i get to a red light it surges then the engine cuts off. We check for vacume leaks and there are none. What the hell could be the problem? By the way the car is an aode.
