intake leak
  • Thread starter Thread starter DMAN302
  • Start date Start date Apr 24, 2004
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Apr 24, 2004
  • Apr 24, 2004
Hey guys,
my 88GT has an eldlebrock performer RPM intake and I noticed two screws on the upper intake were striped (old owner was an ass) the screws were front passenger side of intake and the one right behind that, could this lead to the missing at idle i've been experienceing and the hanging idle??? Going to install helicoils tomorow and tighten it all down..hope this solves problem..I've tried every thing..and i mean everything else.
N
Na5.0HO
342
Michigan
Apr 24, 2004
  • Apr 24, 2004
I've got the Performer 5.0 Intake and am only running on 4 out of 6 upper intake bolts as well. Haven't had a problem with it, although I had plenty of intake leaks with my stock intake and I can't think of it ever causing a hanging idle or misfiring. I would think it would have something to do with your spark plugs or wires because of the misfiring and/or possibly the TPS. These are just my thoughts.. hope they help some. BTW, where do u go about getting helicoils neways??
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Apr 25, 2004
  • Apr 25, 2004
Well plugwires, IAC and TPS are all new and TPS was set properly, butterfly is seating good in THrottle body and Im getting 20HG at the tree with vac gauge. All lines check out fine...then i notice I can turn two screws on my intake with just my hand which I know is bad so I figure this would likely be a place where unmeetered air could enter, but id still like to know since like you said you have 2 bolts missing with no problems, would mine be affected more because its speed density and SD cars are more reliant on vacuume?
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
C
Engine Code 13 and high idle
  • CmdrDerp
  • Dec 14, 2024
Fox 5.0 Mustang Tech Dec 21, 2024
manicmechanic007
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
