- Feb 23, 2009
- 7
- 0
- 0
Im getting a air leak where the gasket from the intake manifold goes to the upper plenum, causing P0174 and P0171 (running lean on both banks). The brass fittings are the cause they want to pop out from the manifold preventing it from getting a good seal. Is there any way I can jb weld the fittings in or buy new ones?
I also believe I have a bad flexplate mabey one in 15 starts will cause a grinding/clunck and the engine will stop turning for a sec, along with some vibrations at idle and a feint clinking noise comming from that area. Does this sound right?
