  • 1994 - 1995 Specific Tech
intake manifold question
  • Thread starter Thread starter 1994Vib.RedGT
  • Start date Start date Aug 22, 2004
1994Vib.RedGT
585
Denver, CO
Aug 22, 2004
  • Aug 22, 2004
what is the difference between the upper and lower intake manifold, and are they sold as one piece or two. I was also looking at two different ones, the Ford Racing 94-95 Cobra, and the Edelbrock Performer. between those two which has more power, which costs more, and which is the better value? I really like the cobra one because of the 5-Liter Cobra plate on the top of it. but which one do you guys thing is better
baglock1
The Bartender
6,612
Space Coast, FL
Aug 22, 2004
  • Aug 22, 2004
The lower is the portion that bolts to the heads. It also has water jackets in it for cooling. It actually distributes the air to the cylinders.
The upper bolts to the lower and has the throttle body bolted to it. It takes the air from the TB and acts as a holding area for distibution to the lower. This helps smooth out the air and works better for N/A EFI applications.
Usually, a manifold is sold with both pieces, upper and lower. Occasionally however, it's just one piece but will say it's just a lower or just an upper.
The Cobra is a very good manifold, but the edelbrock flows better.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 22, 2004
  • Aug 22, 2004
You can find a used cobra intake on ebay pretty cheap. I opted for the cobra because I liked the way it looked and it does flow pretty well. The edelbrock flows a little more but are not found used as much as the cobra.
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 22, 2004
  • Aug 22, 2004
If I were doing it again, I think I might choose the Cobra over the Edelbrock. You can get the Cobra ported so that it flows damn good (enough for an H/C/I 302 at least), and it doesn't have a bolt in the middle of the upper intake...
(yes, I really do hate that bolt. I almost want to get an RPM upper so I never have to deal with it again).
Dave
Joes95GT
3,132
Delaware
Aug 22, 2004
  • Aug 22, 2004
Dave
Is it really that bad, or are you just being anal?
Joe
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 22, 2004
  • Aug 22, 2004
Probably a bit of both. It takes 10 or 15 minutes to get that bolt out, because you can only turn it a sixteenth of a turn at a time. And because it has threadlock on it, you have to use a wrench until it is all the way loose. And it's so tight in there that it's hard to work your hand in there to get it started when you're putting it back in.
See, told ya I hated that bolt. The eddy performer is the only intake I know of that makes you reach inside of it for a frickin' bolt...
Dave
SN95StangMan
1,292
Lynwood, CA
Aug 22, 2004
  • Aug 22, 2004
They dont all have that plaque. Some of them come with the "Ford Motorsport SVO" plaque on it. It's still the same intake though. You can buy a 5.0L Cobra plaque somewhere, I just can't remember where.
viperos
2,943
Bellevue, WA (yes, the land where every 16 year o
Aug 23, 2004
  • Aug 23, 2004
2 peace
R
Road_Runna
20+ Year Stangneter
Dec 23, 2002
594
Ogden, UT
Aug 23, 2004
  • Aug 23, 2004
Dave
You don't need to thread lock that bolt, and if your constantlly removing the upper it woud be a pain in the arse. It takes me 2- 4 minutes to remove it.
VIPERn94Five-0
3,352
Poughkeepsie, NY
Aug 23, 2004
#10
  • Aug 23, 2004
  • #10
you dont need to thread lock that bolt but I did, and would do it again if I took it off...I wouldnt want that thing backing out of the hole INSIDE of my intake manifold...thats lights out for your motor...i threadlocked the crap out of mine lol....
i do agree with you though dave, thats one drawback to the performer...
Anthony
1994Vib.RedGT
585
Denver, CO
Aug 23, 2004
#11
  • Aug 23, 2004
  • #11
If I went with the used cobra intake, how many miles is too many for a used one, is there anything wrong with used manifolds, and how much should i expect to pay for a used cobra upper and lower
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Aug 23, 2004
#12
  • Aug 23, 2004
  • #12
A ratchet wrench with that plenum bolt takes about 15 seconds to remove.
Get the Performer it's a great intake.
95Vert
1,785
North Mexico (deep south Texas)
Aug 23, 2004
#13
  • Aug 23, 2004
  • #13
idk about the performer, i have the cobra and i did notice an increase after the 3000 range. my problem is that i have the stock exhaust on so it's not working to it's full potential, but since you do have exhaust, you will notice an increase. i don't think mileage really matters, or maybe it does. as long as the intake isn't broken or cracked it should be good to go
teamgs
140
Elk Grove, CA
Aug 23, 2004
#14
  • Aug 23, 2004
  • #14
Dave
I don't have that intake, but one of my ratchets has a t-handle at the end, that allows me to twist it and remove bolts after first breaking it loose in the "normal" manner. I would think that it would make short work of that bolt. I seem to have gotten it at WalMart, of all places, years ago, and use it ALL the time.
Here's a link to the same model:
http://www.jcwhitney.com/webapp/wcs...alogId=10101&storeId=10101&langId=-1&TID=1544
Regards,
Gary
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
351W/5.8 EFI intake manifolds fading away...
  • Ryno5150
  • Jan 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
nickyb
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
Engine Retorque lower intake manifold bolts
  • 91GTstroked
  • Sep 8, 2025
Fox 5.0 Mustang Tech Sep 8, 2025
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
