  • SN95 4.6L Mustang Tech
Intake Plenum
  • Thread starter Thread starter Cory281
  • Start date Start date Jun 5, 2006
Cory281
240
Jun 5, 2006
  • Jun 5, 2006
Hey guys, yesterday I took off my intake hose to get my air filter out and I was looking at my throttle body and I turned the butterfly valve and suck my finger past it into the plenum and there is a ton of black stuff all over in there. I've noticed the car feels like it has lost power, so I have a few questions.
Why is this happening?
How can I clean it?
I'm kinda thinking maybe it's running rich? I don't really know, thanks for the help! :SNSign:
BurningRubber
1,865
24
58
Jun 5, 2006
  • Jun 5, 2006
There would be a sooty carbon (black) buildup in the exhaust if it were running rich, not the intake or plenum.
Do you have a K&N filter or anything? They let a bit more dirt through than a normal air filter. Its not uncommon to have a little bit of dirt in the throttle body or plenum.
Check and see if your PCV hose, intake air temp sensor, or the IAC hose is loose and letting unfiltered air in.
You may as well jump on the band wagon and run some Seafoam through the motor if you are comfortable doing so... if theres alot of buildup in the combustion chamber that will take it out.
DTNODYA
831
  • Jun 5, 2006
I would recommend that you take your TB off and clean it with some 'throttle body cleaner'. Not carb cleaner or brake cleaner .... TB cleaner! I know, Ford says not to because of some "special coating" but you can just use a rag, spray cleaner on the rag and wipe that crap out.
When I replaced my intake I had to take all that crap off anyway ... mine was nasty as hell too. I cleaned it as described and it helped substantially. They just get nasty over time ...
Cory281
240
Jun 5, 2006
  • Jun 5, 2006
I think I it is in my exhaust tips too. Everything is on tight and I do have a K&N filter. The weird thing is that the throttle body is really clean, all of this crap is in the plenum. Tomorrow I'm going to tear it apart and clean it out, so I should use throttle body cleaner to clean the plenum?
Oh and I did run some sea foam in it a few months ago, should I give it another go?
Thanks.
BurningRubber
1,865
24
58
Jun 6, 2006
  • Jun 6, 2006
If your taking the TB off to clean it, may as well take the plenum off to clean it as well. TB cleaner will work fine on it.
If you just did a Seafoaming I wouldnt do another so soon, probaly not much back in there. How much came out last time?
jivepepper
776
Under a Sombrero. in WV.
Jun 6, 2006
  • Jun 6, 2006
Some is normal it comes from the egr valve.
Cory281
240
Jun 6, 2006
  • Jun 6, 2006
It smoked about 2 blocks maybe 3 down the street and that was it. The plenum is the dirty part and the back of the throttle body. The front side of the tb is clean.
Thanks for the replies, I'm going to clean it up, I'm going to the track this Friday, anything else I should check up on?
F
ForPointSex
395
Mercer, NJ
Jun 6, 2006
  • Jun 6, 2006
Try using some seafoam.
StangPro
441
Roseville, MI
Jun 7, 2006
  • Jun 7, 2006
This is a combination of EGR soot and oil from the PCV system. The modular engines pull quite a bit of oil (about 1-2oz. a week is normal) plus the soot from the EGR.
You can clean it, but without an oil seperator (and weekly emptying it) and blocking off the EGR it'll just be sooted up again in a week.
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
  • Gulftown980x
  • Jul 29, 2026
squeak93
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
