Intake Suggestions?
  • Thread starter Thread starter chezwic
  • Start date Start date Aug 30, 2005
C
chezwic
14
Allentown, PA
Aug 30, 2005
  • Aug 30, 2005
I've got a 93 LX with the list of mods below. I'm looking to get a new intake manifold and MAF sensor as well. I'm looking for suggestions from the all knowing Mustang gurus. What would be the best intake to get with the super charged setup I have below. Also, I'm thinking that an upgrade at MAF would be quite beneficial too.
Also, where could I find performance comparisions and ratings on Intakes?
Thanks in advance!
306 c.i.d. Ford Racing Short Block, Trick Flow Twisted Wedge Heads, Cobra Upper and Lower Intake, 70mm BBK/Edelbrock Throttle Body, 1.7 Ford SVO Motorsport Roller Rockers, Ford Racing E-303 Cam, D-1SC ATI Procharger w/3 Core Intercooler, Custom E-prom, 42 lb. Ford Racing Injectors, Univer Mass Air Meter, 255 Lphr Fuel Pump, MSD 6AL Ignition Box, MSD TFI Coil, BBK Equal Length Headers, BBK H-Pipe With Cats, Flowmaster American Thunder Exhaust, Tremec TKO Transmission,
1EVIL88VERT
314
Dyess AFB, TX
Aug 30, 2005
  • Aug 30, 2005
with your setup i would go with the downs racing gt-40 box upper and port the cobra/gt-40 lower you have, it would work great with the blower.
vikingpower
656
CWU Ellensburg, WA
Aug 30, 2005
  • Aug 30, 2005
Get a hot street/strip manifold with long runners so you dont lose low and mid-range torque: RPM II, Systemaxx etc... If you spend a lot of time over 6000RPMs go with a Victor5.0 or TFS Box-R
V
v8only
2,378
22
49
Aug 31, 2005
  • Aug 31, 2005
forget the intake, you need to address a lot of suspension issues, unless you left that out of your mods list. You need to start with upper/lower rear control arms, and maybe a little more gear (not too much because of the sc) That'll get you a hell of a lot more time than an intake upgrade at your point in the game.
However, my buddy is running an edelbrock rpm2 intake with afr165's, and every bolt on in the planet, and a custom cam. He put down just shy of 325 at the wheels, and 12.1's
C
chezwic
14
Allentown, PA
Aug 31, 2005
  • Aug 31, 2005
I already have the suspension stuff addressed. I left that out of the mods b/c it wouldn't fit in the signiture. Some of the items are:
sub-frame connectors, Hurst roll control, lowerd racing shocks, Ford Racing Lowering Springs - Super Sport, BBK Caster/Camber Plates, MAC Upper and Lower Control Arms, Precision Gears 3.73, 31 Spline Hardened Moser Axles, Eaton Posi, Mac Rear End Cover/Girdle, 5 Lug Conversion.
Right now I'm putting 476 rwhp to blacktop. It's the best of both worlds. It screams when I gun it, yet it idles a 750 rpms and I can lug thru stops signs in second gear. I've been told that my current intake is like a restrictor plate.
blwngt
12
  • Aug 31, 2005
holley systemax.....no question...
ZetecF1
25
MN
Aug 31, 2005
  • Aug 31, 2005
Are you stupid or just slow?
9
93gtstang1
94
Mason, Ohio
Aug 31, 2005
  • Aug 31, 2005
i say Trick Flow Track Heat it will go great with your trick flow heads and the track heat flows really well. just my honest opinion
Sicarius428
2,085
Aug 31, 2005
  • Aug 31, 2005
Edelbrock RPM2 or TFS track heat would work well with your setup. Not the GT40 because the GT40 has a smaller throttlebody opening.
Kevin
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Aug 31, 2005
#10
  • Aug 31, 2005
  • #10
The Holley is used in quite a few blower applications and I think it is a good choice also. Haven't seen any RPMII's used yet, but no reason to think it wouldn't work well.
A professional porting of that lower intake will make a difference that would please you too. Take a look around the photo section of my website ........
87AODGT
373
Toms River, NJ
Sep 1, 2005
#11
  • Sep 1, 2005
  • #11
I've got an RPM II on my blower setup, switched to that from a GT40 and let me tell ya, over 3500 it pulled a hell of alot harder even when I ran it without the blower hooked up it felt alot better up top. also went from makin 10psi as soon as the converter flashed to only making 8 and then getting up to 10 right around 5500, that alone shows an improvement in airflow
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
  • dan50
  • Jul 18, 2026
dan50
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
