intake
  • Thread starter Thread starter ATI_blown92
  • Start date Start date Jun 16, 2005
A
ATI_blown92
26
clifton, nj
Jun 16, 2005
  • Jun 16, 2005
in the process of my holley systemax install when i realized i only have a 65mm TB i was looking at teh holley 75mm TB but it say somethign about it having to me ported to match the intake,is this tru considering i havea holley intake
SlowGT
826
Columbia Co, PA
Jun 16, 2005
  • Jun 16, 2005
Usually it's the intake that needs to be opened up to match a larger TB.
z2o_what
309
princeton, WV
Jun 16, 2005
  • Jun 16, 2005
the holley intake probally already has a 75mm opening...what you are reading is probally talking about using a 75mm tb with a stock intake
but if your car is N/A i would stick with the 65mm
TrickFlow
340
Bossier City, La
Jun 16, 2005
  • Jun 16, 2005
Actually, i just read a comparison of like 8 different efi intakes. they went from stock all the way to a 90mm, and said that only 1 out of them was actually the correct size hole. Even tho your intake says it has a 75mm opening, more than likely for it to fit right, it will need some minor massage work to open up the hole a little. Take your thottle body, stick it over the intake and bolt it on there...(preferably with the intake off) open the butterfly, and look thru it and look to see if you can still see any of the intake thru the throttle body. if you can see that the intake hole is actually smaller, take a marker, and draw the inside line of the throttle body, then unbolt the throttle body, and have fun with a dremel.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
Someone help me understand this, Intake opening to throttle body opening
  • from6to8
  • Jul 11, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
from6to8
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
