Intake ?
  • Thread starter Thread starter Roland69
  • Start date Start date Apr 6, 2006
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 6, 2006
  • Apr 6, 2006
Will a upper intake from a 95 Explorer 5.0 bold right on to my car or was there something that needed to be done to make it work. I tried a search but a S-h-i-t load of intake stuff came up and couldn't really find what I was looking for.
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Apr 6, 2006
  • Apr 6, 2006
The upper intake from an Explorer was designed for a gt-40 lower intake... IE: Cobra
If you have the stock lower manifold it will NOT bolt up as the stock manifold ports are somewhat oval in design and in a line while the gt-40 is round and staggered.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 6, 2006
  • Apr 6, 2006
so if I get a lower intake aswell every thing else will bolt right on
poneypower89
Dec 6, 2004
Apr 6, 2006
  • Apr 6, 2006
If you have the upper and lower.. yes the setup will "bolt-on".. however, somewhere in the model run for explorers the intake changed a little bit and required the mustang user to do a few modifications for egr and stuff like that.. Cant remember exactly but I've definetly seen the write up on how to convert it to a mustang when I was using the search function some time ago.
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Apr 7, 2006
  • Apr 7, 2006
If you have the upper AND LOWER it will bolt right up, I have a 95 on mine and egr was all fine, along with it coming with the act location find on the number five injector. May have to drill and tap for the act, but that is easy to do if need be, but I don't think you'll have to. I recommend o'reilley auto parts for the gasket kit, is only like 19 bucks for the cobra/gt40/explorer gasket set. Also get a fuel line tool kit to remove the fuel rails. I'll see if I can't find the set up and list of things, I'm pretty sure jrichter posted all the things needed if you can search his posts and find them.
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Apr 7, 2006
  • Apr 7, 2006
Did they put the 5.0 in the 95 Explorers?
2000xp8
SN Certified Technician
Aug 8, 2003
8,076
1,659
194
NJ
Apr 7, 2006
  • Apr 7, 2006
I don't think they did.
aete2
554
  • Apr 7, 2006
Im pretty sure they did in 95 the first year !
2000xp8
Aug 8, 2003
8,076
1,659
194
NJ
Apr 7, 2006
  • Apr 7, 2006
If they did, it's rare, so far on ebay, autotrader.com, autoshopper.com, i yielded 1 find, and i could tell it was a misprint, so...
I made a post on my explorer forum, and we'll see what they say.
aete2
554
#10
  • Apr 7, 2006
  • #10
cool good to know thx!
RBRANDX
110
Myrtle Beach, SC
Apr 7, 2006
#11
  • Apr 7, 2006
  • #11
Not a 100% on the 5.0 in the explorer, but I kow for a fact that they put in in the Mountaineer for several years..My uncle had one.
2000xp8
Aug 8, 2003
8,076
1,659
194
NJ
Apr 7, 2006
#12
  • Apr 7, 2006
  • #12
Well, the guys answered me, no 5.0's till 96, and no mountaineers at all until 97.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 7, 2006
#13
  • Apr 7, 2006
  • #13
This is why I asked but I missed it anyway's
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=8052657539&rd=1&sspagename=STRK%3AMEWA%3APIC&rd=1
2000xp8
Aug 8, 2003
8,076
1,659
194
NJ
Apr 7, 2006
#14
  • Apr 7, 2006
  • #14
That was the gt40 style off of a 96 and newer. Wouldn't of fit on your stock lower intake.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Apr 7, 2006
#15
  • Apr 7, 2006
  • #15
I got mine off a 96 Mountaineer with the 19# injectors and 65 MM throttle body for $250.
The ACT (Air Charge Temp) sensor will probably need to be moved. The GT 40 lower manifold isn't drilled & tapped for it to go into the intake like the stock manifold was. There is a boss cast into the GT 40, but a machine shop will have to drill & tap the new manifold. The best spot for the ACT is the air box if you don't do the drill and tap thing. You get to cut and splice the 2 ACT wires in order to make them long enough to reach the air box. Solder the wire extensions on the existing wires & use heat shrink tubing to cover the splices. Offset the place where you cut the wires so that you don't have a big bulge when you put heat shrink over the 2 wires to cover & protect them. The air box gets a hole (5/8" or so) for the ACT drilled about 1 1/4" down & 1/1/4" in on the front top side near the upper radiator hose. A brass fitting nut from Home Depot or Ace Hardware secures the ACT into the air box.
If you are very clever, you will find that the ACT connector comes apart so that you can remove the pins. A very small screwdriver releases the lock in the front of the center insert, while another small screwdriver inserted in the back pushes it out. Once the center insert is out of the connector shell, the pins come out easily. New pins are available from AutoZone in a $5 electrical pin kit for Fords. Crimping the pins on the extender wires saves you from having to splice them twice: once to put the connector on and once to extend the wires.
6 ft black 18 gauge wire
6 ft green 18 gauge wire
6 ft 1/4" heat shrink tubing
1 ft 3/16" heat shrink tubing
Measure the 2 extender wires & cut them to length, crimp one set of pins on them. Then mate up the extender pins with the wiring harness & slide the 3/16" heat shrink tubing over them & shrink the tubing. Then slide the 1/4" heat shrink tubing over the pair of wires and shrink the tubing. When you are done you'll have about 1" of wire left without heat shrink tubing on it to strip & crimp the new pins on. Stick the new pins in the old connector shell, assemble it and you are done. It looks as good as factory. Some wire loom can be used to enhance the "Factory Look".
Use the TPS and IAB from your old throttle body. All the EGR passages were there and fit OK. Use you old fuel rails and regulator. You will probably need a new EGR spacer adapter and gaskets. Without the EGR spacer, there is no place to mount the throttle linkage support bracket.
I used the stock water lines on the Explorer manifold and they connected up to the EGR without any problems. I made a “U” out of ½” copper pipe and sweat soldered it together. Then I used it and some hose with clamps to bypass the leaky heater I have. You don't need heat very often here in Central Florida...
The vacuum lines you need are 1 small line for fuel pressure regulator, 1 small line for A/C,1 small line for EGR and another small line for the smog pump. One big line at the back goes to the vacuum tree for the power brake & A/C, one big line goes to the PVC valve. The other big line goes out the front for the carbon canister. In a pinch, one of the small lines can connect to the spare port on the vacuum tree. Cap or plug the remaining lines since they aren't needed.
The stock Explorer linkage didn't come anywhere near fitting, so I made an adapter plate for the throttle linkage so I could use the 65 MM throttle body.
This is what I did:
Make a drawing of the position of the old throttle body linkage arm and its angular position relative to the centerline of the throttle body. Remove the ball stud off the explorer TB to make way for the adapter plate. Drill and tap a 10-32 hole in the linkage parallel to the TB shaft. Make an angle bracket out of 1" angle iron 3/8", drill a 3/16” hole in the center of each one of the legs. Then bolt it on where the hole was drilled & tapped. Then make a circular adapter plate out of 1/4" thick aluminum to bolt the two linkage arms together. Then bolt the aluminum plate to the existing linkage, and the angle bracket. Next mount the arm with the ball stud off the old throttle body on the adapter plate using the drawing to get the angle correct. You will need an aircraft type countersink for one of the bolts that secures the plate to the explorer linkage arm. It ends up being under the arm with the ball stud for the linkage. It works great and looks neat.
A trip to the welding shop with the explorer TB and the arm from your old Mustang TB would probably accomplish the same thing. I didn't have access to a welder, so I fabb'ed the plate in my shop. I took about 1.5 hours to do it, it was a measure, cut, and fit type of operation.
Also see http://www.veryuseful.com/mustang/tech/engine/ConvertingExplorer65mmTB.pdf for modifications to adapt the 65 MM Explorer TB to a Mustang
Vacuum line connections:
One large vacuum line from the upper front goes to the carbon canister
One large vacuum line from the rear goes to the vacuum tree.
One small line in the front feeds the Smog pump solenoid control valves on the rear of the passenger side wheel well..
One small line in the rear goes to the fuel pressure regulator.
One small line in the rear goes to the EGR suction regulator.
One large line in the rear goes to the PVC valve.
Here's some tips...
Tools: a good torque wrench is a must have item. A razor blade scraper that holds a single edge razor blade from Home Depot or Ace hardware is another handy thing. Get a Chilton or Haynes shop manual - you'll need it for the bolt torques and patterns. The intake manifold has an especially odd pattern. You'll need access to a timing light to set the timing after you re-stab the distributor. Look in the A/C repair section for the fuel line tools. They look like little plastic top hats. You will need the 1/2" & 5/8" ones. The hat shaped section goes on facing the large part of the coupling. Then you press hard on the brim until it forces the sleeve into the coupling and releases the spring. You may need someone to pull on the line while you press on the coupling. Put some motor oil on them when you put the line back together.
The A/C Compressor comes off with lines still connected. Mark all the electrical, smog and vacuum lines with tags to help you remember where to re-connect them. If you have a digital camera, take several pictures.
Whatever you do, don't skimp on cleaning the gasket surfaces. New gaskets need to seat against bare metal and not the residue left from the old gaskets in order to seal leak free. This is the most time consuming and tiresome part of the job. Look for little things that need to be replaced like the short hose from the thermostat hosing to the water pump, damaged vacuum lines and hose clamps that are rusted or broken.
Plan on cutting the thermostat to water pump hose, or removing the thermostat housing. Also plan on removing the distributor to get clearance to remove the intake manifold. Remove #1 spark plug, stick your finger in the spark plug hole and crank. When your finger gets air moving past it, stop cranking. Turn the engine until the timing marks line up with the pointer. Now you can pull the distributor out.
My favorite trick that saves time and effort is the stay in place gasket. Be sure that you scrape (don't use a wire brush) all the old gasket material off, then clean all the surfaces with acetone or MEK.
When the surfaces are clean, use weather strip adhesive on the head to manifold surface, and on the side of the gasket that mates to the head. Follow the instructions on the tube or can and when it gets tacky, press the gasket down on the head.
Clean the area where the rubber rails mount to the block in front and in the rear with more acetone or MEK and do the same trick with the weather strip adhesive that you did to the heads.
Coat the rubber seals and the gasket area around the water passages with lots of Blue Silicone gasket sealer and put it together. Wala! no leaks, and no gaskets that shifted out of place.
If you reuse the injectors from your old setup, a repair kit is available from most auto parts stores if needed. Coat the injector body "O" rings with oil before you use them and everything will slide back together. Take the other advice you got here and run with it.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $2.74 per kit. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber.
Consumable items:
Upper manifold gasket
Fel Pro 1250 or equal lower manifold gasket set.
Short formed hose between thermostat hosing and intake manifold
6 ft 7/64" or 1/8" vacuum hose
2 ft 1/2" heater hose
1 1/2 ft 5/8" heater hose
Blue Silicone sealer
ARP antiseize or equal for the bolts
4 each 3/4" hose clamps (spare item in case the old ones are bad)
4 each 1/2" hose clamps (spare item)
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 7, 2006
#16
  • Apr 7, 2006
  • #16
Wow thats alot of info thanks jrichker
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Apr 9, 2006
#17
  • Apr 9, 2006
  • #17
That intake is off a 97 up car - it has no internal EGR passages wgich the 96 and very early 97 intakes had.
Engine Explorer - Lower intake internal cleaning
  • R82148V
  • Nov 11, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Dec 6, 2025
rednotch
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
G
Engine PATS off pcm for 1999 Explorer 5.0 swap
  • GOvert
  • Dec 23, 2025
Fox 5.0 Mustang Tech Jun 14, 2026
GOvert
G
95-early 97 Explorer upper and lower intake manifold - NO LONGER NEEDED
  • R82148V
  • Jul 11, 2025
  • Want to Buy
Want to Buy Oct 31, 2025
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
