Hi everyone, I hate asking questions because I don't have a mustang yet, but I'm getting there, saving saving. Still dreamin', as StangDreamin' says.
The combo I want to build is a 331 roller motor, for a beasty little street motor. That's about all that matters for this question I suppose.
I was browsing through websites for information, and one VERY good bit came up, that I hadn't thought of. You see, I want to put a custom fuel injection setup on it along with the rest of the build. The website I found said not to use a new FI setup on a freshly built block before run-in, because by the time you have it tuned good enough to drive, you'll have gone past the break-in stage, and probably washed the cylinders running rich, and ruined rings, that sort of thing.
This dissapointed me a little, BUT then I thought hang on, firstly it'll be cheaper to initially run a carb and a good ignition system and so is more feasible, and give me a chance to build it up again later, and break it in properly.
So what carb, manifold, fuel pump (if there's any better quality mechanical pumps, or an electric I can run with a carb), and ignition stuff is good?
I've heard a lot about the MSD 6-AL, so I checked that out, and saw a distributor I could get from them to go with it. What's a good coil? MSD I'm guessing...
I'm not too well versed on the fuel system either, except that I might not be able to run a mechanical fuel pump with some of the accessories I will put on the motor, not sure yet. What's a good mechanical pump? Electric?
I like the look of the air-gap manifold, would that be a good one to get? Any better? I want to be able to drive it, and would rather good torque over max power and rpms.
I like the look and reports I hear about demon carbs too, so what cfm would be best? Any other carb anyone would reccomend?
Thanks, hope you guys help me out.
, I want to get a Dart aluminium block, I know, 'round 5k for a block, but my angle is ultra light, and nothing un-necessary. (until I get air-con
