intakes
  • Thread starter Thread starter Project 77
  • Start date Start date Apr 5, 2004
Project 77
370
Bernville PA
Apr 5, 2004
  • Apr 5, 2004
What intake do you guys recommend? I have a holley 600 single feed double pump. I was going to go with a Weiand stealth
77sleeper
GO BUCS!
7,266
Napalm, AZ
Apr 5, 2004
  • Apr 5, 2004
I have one, it is great, watch out for hood clearance though
D
dmoody
789
Winston-Salem, NC
Apr 5, 2004
  • Apr 5, 2004
With Edelbrock Performer or Performer RPM you'll have no clearance problems. Also Edelbrock is made in the US.
d
98CobraClone
592
Ripley, Ohio
Apr 8, 2004
  • Apr 8, 2004
me and Stang2Man both have Edelbrock Performer 302 intakes on the II's and have not had any problems whatsoever. Great low end torque.....and it's fair at high RPM's. If it's gonna be a daily driver, I'd highly recommend a dual plane low rise......any company should do
Z
zwhitr
847
Goldsboro, NC
Apr 8, 2004
  • Apr 8, 2004
Iv'e got the performer had mine for 15 + years ditto on the dual plane
C
COBRAIIW
562
CT
Apr 8, 2004
  • Apr 8, 2004
My Offenhauser 360 dual plane, with Holley 600 works quite well on the 351.
cobra_2_76
201
Norwalk, Ohio
Apr 9, 2004
  • Apr 9, 2004
Brian,
Weiand Stealth and Edelbrock Performer RPM are the same height so hood clearance problems will be the same. Check the specs so on the Summit site.
Also contact me about Nashville ASAP.
Thanks
Dave
1badII
796
Durham, North Cacalaky
Apr 9, 2004
  • Apr 9, 2004
I'm running a Performer RPM Air Gap, and I just barely clear the hood. My air cleaner is about 1 1/2" or so tall, and I use a bolt to hold it down instead of a stud and wingnut.
H
HaveII
272
Houston, TX
Apr 9, 2004
  • Apr 9, 2004
I had an Edelbrock Performer that I replaced with an RPM Airgap. It is a tight fit for hood clearance, but the performance is better all round. I used an air cleaner that drops the base 1" below the top of the carb. I used a 2 13/16" element in it along with a bolt that is tightened by a flat head. It does not hit the hood, but using any plates or spacers between the carb and manifold is not an option. Also I am using a Carter 625cfm afb. I don't know if the Holley is taller or would allow the use of this type of air cleaner.
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
