https://www.fleet.ford.com/downloads/specvehpolice/police.pdf
CROWN VICTORIA POLICE INTERCEPTOR FEATURES
Alternator, heavy duty 135-amp maximum
output, 82-amp at idle w/unique drive pulley
for improved charging system
• Axle ratio, rear 3.27:1 with non-locker
differential
• Battery, extra heavy-duty, 78 amp-hr (750
CCA) with heat shield
• Conventional headliner without grab handles
• Cooling Package; Police level, with 8 blade
plastic fan, dual speed electrodrive fan motor
and lower radiator air dam
• Decklid release located on instrument
panel, direct to battery (gasoline fueled
vehicles only)
• Drive shaft, aluminum 3-1/2" heavy-duty
and heavy-duty u-joints (n/a with Natural
Gas Vehicles)
• Engine, gasoline, 4.6L overhead cam, SEFI
V8, unique with Police Pursuit calibration
including increased idle speed for improved
charging system output and cooling
• Increased horsepower, to 235 @4750 RPM
and torque, to 275 Lbs/Ft @ 4000 RPM
• Engine oil cooler
• Personal safety system – includes safety belt
pretensioners, front dual stage air bags and
seat position sensors
• Power steering gear, heavy duty, unique, for
improved road feel, with front-mounted oil
cooler, without speed sensitive variable assist
• Front seats, cloth bucket – manual reclining
with anti-stab plate driver/passenger, with
power lumbar on driver’s side and weapons
cut-outs
• Suspension, police, heavy duty front and rear
springs, shock absorbers and stabilizer bars
• Tires, P225/60R16-97V Goodyear BSW, allseason
speed rated with conventional spare
• Transmission oil cooler, external, front
mounted
• Wiring, courtesy lamp
• Accessory feed wires, police:
· One ignition feed (3 connectors, 30-amp fuse)
· One direct feed (3 connectors, 50-amp fuse)
