The reason that turbo guys run intercoolers is because they run off exhaust gases. You don't need an intercooler with a supercharger. If the kit comes with one, I say go for it, but otherwise don't waste your money
I wouldnt feed this kind of stuff into his head, hes going to get the wrong idea here.
Turbo guys use intercoolers because they usually run more boost then blower cars. Its not nessarly that the inlet temps are any warmer with a turbo as aposed to a blower. Both create boost, which creates a ton of heat, which leads to detonation.
If anything, blower cars need an intercooler just as much as any turbo car would.
I think its really stupid to not include one in the 94-95 Vortech kits. The 4 valve cars have an aftercooler, as do the Foxes, but they do not make one for the 94-95's unless you go with a Procharger.
more boost you run, the more likely the car is to start detonating, without an inter/aftercooler, that is.
Ide just buy a procharger if your set on a blower.. They allow for higher boost levels, because of the supplied intercooler.
