crushnut said:Has anyone ever heard of breaking a new cam in by operating it at 2000rpm for 10min, 1200rpm for 10min, and 1600rpm for another 10min? I was always told and read to do it a 2000rpm for 20min.Can anyone back this up or does it not matter.
Thanks
PoliceInterceptor said:Also if your cam kit did not come with an oil additive (or the company doesn't sell one, Both Crane and Comp do) add a can of GM EOS (Engine Oil Supplement) to the oil before firing it off.
HTH
crushnut said:If you dont mind me asking, what does that stuff do? And where can you get it.
Thanks
PoliceInterceptor said:I agree to follow the cam manufacturers directions, most of them say not to let it drop below a specified RPM for 20-30 minutes. Varing the RPM above that RPM still follows the directions.
What kind of cam are you breaking in?
PoliceInterceptor said:The story is that it contains zink which has been removed from most oil, and is said to be an EP lubricant.
Isky and Lunati specifically say use GM EOS, Crane and Comp have their own "Break In lube".
crushnut said:Does anyone know where you can buy this stuff ?
Thanks
