Interior brake light comes on
Lauras5.0Vert
Hi
I have a 92 5.0 convertible with approximately 135K miles on it. Recently, when accelerating, my brake light on the dashboard flashes on for about 10 seconds or so then goes out. My first thought was that I needed brake fluid but unfortunately it wasn't something as easy as that. Any ideas as to why this is happening? Thanks for any help you can give me.
Laura:rolleyes:
check your fluid level in the reservoir its low and when you accelerate the fluid is drawn to the rear of the reservoir causing the float to drop and the light to illuminate and when the fluid levels out after acceleration the float rises and light goes out ....
95Vert said:
Either that or you're low on brake pads in the rear. This has happened to me in other FORD vehicles. Check it out.
this is true in a sence the reason your reservoir is low because when the pads wear over time the fluid moves into the calipers from the reservoir i would inspect the brakes too after adding fluid to the reservoir...the only reason the brake light on the dash will illuminate is if your brake fluid reservoir is low or brake fluid reservoir sensor is bad or the emergency brake is applied or the emergency brake sensor is bad or loose...
Thanks for the help
Thank you all for the responses. I checked the fluid in the reservoir and it was OK. Funny thing is, the other day I had the state inspection done on the car and was told by the inspector that he would pass the brakes that day but that I need new pads in the front. I am going to go ahead and have the pads replaced today or tomorrow and see if that works. Thanks again for all of your help.
Laura:D
