Interior getting HOT!
KlrSnk
What could cause my shiftboot, console around the shifter and the carpet in the ashtray hole to get HOT? I was driving the 90 today, grabbed my lighter out the the ashtray hole and it was ridiciously hot, i felt around and noticed the other parts were hot too.
What could cause this? Exhaust?
First I would check if that little metal-rimmed rubber boot is still around the shifter. With mine out I could actually feel noticeably colder in the winter, and I assume with extensive driving that the heat from the tranny and exhaust would rise into the cabin.
This one seems a little more far fetched, but you might want to look into replacing the tranny fluid. More friction=more heat.
Just some possibilities
Well as long as it's not excessive, it'a normal for a Mustang.
My '03 does it to. On a warm day if you are wearing shorts your right leg will get a little warm.
It's due to the shape of the trans tunnel and the heat from the exhaust rising up.
Of course if it's warmer than usual, i'd check for a clogged/glowing cat
Thanks guys.
Its not HOT HOT to the touch, but its warm, Ill check next time for the glowing cat, the rubber boot is still there cause I just installed the mgw shifter and replaced it too.
