  • 1994 - 1995 Specific Tech
Intermittent shut off
  • Thread starter Thread starter slimstang
  • Start date Start date Oct 17, 2008
slimstang
  • Oct 17, 2008
I hope someone can help. I have a 94 cobra which sometimes wont start, it will turn over just not start. And sometimes while driving it will either hiccup or just shut off on its own. Ive put on a new fuel pump, not sure what to do next. Ive taken it to have it checkecd course it wont do it while there and cant get diagnosed. Any thoughts?
94GTCoupe
1,412
92
79
CA
Oct 17, 2008
  • Oct 17, 2008
put a spark tester in-line between the ignition coil the dizzy when the problem occurrs.check for spark.
if no spark,it's most likely the PIP within the dizzy.a common problem on our car's.
you can replace the PIP by removing the dizzy and pressing the drive gear off the dizzy shaft.
or,you can get a Reman dizzy from the part's store,but when the dizzy is remanufactured,they only replace the part's that are obviously bad.sometimes the PIP is not replaced,so later on you may find yourself in the same boat.
94GTCoupe
1,412
92
79
CA
Oct 17, 2008
  • Oct 17, 2008
Also, to :SNSign:
desertcox05
379
south atlanta
Oct 19, 2008
  • Oct 19, 2008
i'd bet on the pip in the dizzy too. if you but a reman dizzy then you at least have a guarantee if it fails on you again
hssnpny
49
SoCal
Oct 20, 2008
  • Oct 20, 2008
I also have a '94, and for the past 2 years had an intermittant issue with cutting out. In the last couple months it had started getting worse, and I had just started the part replacement roulette game. It finally threw a code 211, which indicates the PIP. Has your check engine light been coming on? Even if it hasn't, it's worth seeing if any codes are stored. Mine was doing it for over a year without giving a code, so if you have to chose a part to replace next, I vote for the dizzy too.
Good luck.
desertcox05
379
south atlanta
Oct 20, 2008
  • Oct 20, 2008
when my dizzy crapped out it didn't throw and codes
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
