Intermittent Vibration During Acceleration
  • Thread starter Thread starter 03_Stang_GT
  • Start date Start date Dec 6, 2017
03_Stang_GT
  • Dec 6, 2017
Hello, I am experiencing an intermittent vibration during acceleration. It usually starts after shifting into 2nd. My shift knob shakes like crazy. There is no vibration in the steering wheel and it only happens every few days, when I let off the gas pedal it goes away and starts back up when applying my foot to the pedal again. I recently changed the U-joints but that did not help the problem. Any suggestions on what it can be? Thank you in advance.
General karthief
Mod Dude
Aug 25, 2016
28,014
10,641
213
polk county florida
Dec 6, 2017
  • Dec 6, 2017
The engine could be developing a miss, hard to say.
Mattstang04
1,152
144
104
St. Louis, MO
Dec 6, 2017
  • Dec 6, 2017
This one may require some video and audio to figure out.
rancorkeeper
484
Palos Heights, IL (Chicago suburb)
Dec 7, 2017
  • Dec 7, 2017
Considering you just did the u-joints, that would be my suggestion on the first place to check. They could be bad or you could have some loose bolts on one or both ends of the driveshaft connections.
03_Stang_GT
  • Dec 7, 2017
Could a developing misfire not throw any codes and cause vibration? It feels like there's a hesitation in power when I step on the gas pedal.
Thank you guys for your suggestions. Really appreciate it.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 11, 2017
  • Dec 11, 2017
Check for broken motor and/or transmission mounts. Very common problem on the Mustang. A dead giveaway that the motor mounts are broken is that the motor is setting very low in the K-member.
Questions About T5 Manual
  • Blackout67
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
