Is 12° timing fine ?
  • Thread starter Thread starter 86sebring
  • Start date Start date May 20, 2005
86sebring
22
  • May 20, 2005
Just want to double check my timing. I have a 68 block with aluminum heads and a 268 comp cam. I have heard to put it at 12°. Is that good for this combo?
thanks
10secgoal
2,801
San Diego
May 20, 2005
  • May 20, 2005
Each combo is different. Some of us run 20-24. Set it to what runs the best. If it still cranks at 12 ( it should), it's fine as long as your total timing does not cause the dreaded "ping"
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
May 21, 2005
  • May 21, 2005
Yeah, back it off if you get pinging. Sometimes aftermarket heads have better chambers than stock so one might actually run less advance than w/ stock heads. Going up into the 14 degree range may necessitate premium gas. If you dont need preium already, dont start buying it just for a little timing.
G
grego37
576
Fresno CA
May 23, 2005
  • May 23, 2005
which dist. do you have and what type of advance does it have, is it adjustable, or fixed?
84convertablegt
589
Columbus, OH
May 23, 2005
  • May 23, 2005
on my 65, i run 12 degrees initial, with a total of 40 degrees with the vacuum advance. no problems, but i always run 93 octane in the stang
86sebring
22
  • May 23, 2005
I believe its a motorcraft dizzy with single points and vacuum advance.
Am I doing it correctly by unplugging the vacuum hose and setting the timing at 12° at idle speed or do I need to increase the RPM's ?
Its been a while since I last adjusted the timing on a car.
I have a Mallory Unilite dizzy on the shelf somewhere and will install that at a later time.
thanks
HistoricMustang
2,359
Confederate States of America
May 24, 2005
  • May 24, 2005
12 degrees is fine. Remember, initial timing (within reason) is not that important with performance. It is getting the total timing correct.
HistoricMustang
www.historicmustang.com
86sebring
22
  • May 24, 2005
HistoricMustang
What is the difference between initial and total timing? Low RPM's and high?
thanks
84convertablegt
589
Columbus, OH
May 24, 2005
  • May 24, 2005
initial timing is your timing with no vacuum or centrifugal advance, at around 1500 rpm's or thereabouts. whats supposed to happen with a vacuum advance is that as you rev your engine and increase load on acceleration the vacuum advance will start to advance your distributor to your total timing, which is usually around 30-40' advanced. this helps give you more performance. a mechanical advance does the same thing, it just uses the speed of the distributor as a guide to advance the timing. you need to set initial timing with the hose off of the distributor that way you dont get any advance. newer cars are the same way, its just that the computer controls the advance. historicmustang is right, total timing is most important. thats why alot of people lock out there timing with a total advance.
G
grego37
576
Fresno CA
May 24, 2005
#10
  • May 24, 2005
  • #10
chech you total timing when you check / adjust your initial.
Say if you set your initial at 12* (with the hose off the vacuum advance.
then put the hose back on, hold the rpm's around 3500rpm, read your timing.
(this is your total timing)
should read between 34-40?
each engine requires a little different timing, I cant tell you exactally what it should be.
You should start a post asking what your total timing should be. List all of your engine parts etc. etc. Im sure someone has a set up similar to yours and they can reccomend a total timing number.
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
My next project , a 428 build!
  • horse sence
  • Jul 29, 2026
  • 7 8 9
3K
Classic Mustang Specific Tech 10 minutes ago
DadLife0724
Who Is Up To Date On DCC Fan Controllers?
  • BoostedRed89gt
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 26, 2026
revhead347
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Tuesday at 9:33 AM
rednotch
