rbohm said:when using a formula to determine carb sizing, you need to use the rpm at which you develope maximum torque, as that is where your volumetric efficiency peaks. for most healthy street engines that is around 4500rpm. a simpler formula i use, and it does very well by me, is to double the engine displacement and multply by .85 for the street, and .95 for a race motor, and that will get you very close to what you need. as far as your problem goes, you just need to tune your combination better. start by setting your initial timing at 10 degrees, assuming the 13 degree slot on your dist advance mechanism that should set you right at 36 degrees total timing(without the vacuum advance). once you have that set, then hook up the vacuum advance. next you need to tune the holley to your engine, lighter secondary springs, a jet change, go down about 4 sizes and that should put you close, and perhaps even a 1" thick 4 hole spacer.
By that formula, a 393 stroker with AFR 205s and a single plane intake would be just fine with a 675cfm carb. I know that no formula works in all situations, but I think most here agree that a 675 cfm carb on that motor is not near enough.
CFM stands for cubic feet per minute. But who goes WOT for a minute? How about in 10-15 second blasts? While 675 might be the ideal size carb for the motor listed above, a 750 will give you a stronger and faster 10-15 second blast than a 675 will. That not only works in theory, but it has been proven at the strip time and time again.
Holley and Edelbrock err on the side of caution because there has been a history of backyard rodders throwing the biggest carb they can at a motor, thinking that cfm means performance. In this day and age, we know better. Holley doesn't want to sell carbs that are too big for the application and process returns on carbs that don't work for the application.
Quarter mile times don't lie.
Also, remember that Holley are flow tested dry and Edelbrocks are flow rated wet. Wey means there is fuel in the mix, and fuel displaces air. Therefore, a Holley 750 will outflow an Edelbrock 750, for the most part.
Good discussion, by the way....
