Is brake conversion worth it from an 03 MACH 1 onto my 95? help!!!
mustanghunter50
123
easton pa
I can buy a set of rotors and calipers off an 03 mach 1. the fronts are 13" brembos and the rears are 12". I get an extra set of rotors and the calipers come with the set. the guy's asking $200. I'm just looking for some input as to whether or not its worth it to put them on my 95 gt. It'd be awesome if i could get some input.
personally idk if they bolt up but I don't see why it wouldn't be possible. I have 03 Cobra brakes 13"s on the front of mine & the difference is night&day from stock!:nice: I'm positive there are several members on here than can tell you if they will swap over or not.
$200 for everything???? come with the mounting brackets? that sounds like a super steal to me. also, if you get them you will need to swap out your spare for a 17". the stock 15" spare will not clear the 13" rotors/calipers, not sure if it will clear the rears or not though
Yes, it comes with everything, it's a complete set. it only has 10k on it also. the spare tire is no problem....i found a guy giving away a set of american racing wheels (the ones that look like deep dish bullitts) with good tires on them, so i have a spare set of bullitts
i just picked the brakes up and got an extra set of slotted cross drilled rotors, and a battery booster pack with it too. the guy was cleaning out his garage and had to buy something for valentines day, so he needed to sell the brakes asap....so i was a major benefactor of the hallmark holiday!
