  • 1994 - 1995 Specific Tech
is it normal?
  • Thread starter Thread starter Billy8380
  • Start date Start date Feb 6, 2008
Billy8380
68
  • Feb 6, 2008
After my head and tfs1 swap i am on rev limiter at 5200-5300 rpm??
M
mackey
1,284
Beverly, Massachusetts
Feb 6, 2008
  • Feb 6, 2008
Rev-Limiter is set at around 7k on these cars. So no. You probably put the distributor back in wrong or your timing is off. Does it feel like you hit a complete wall and all you hear is basically air being sucked in?
Stanger007
2,015
Baton Rouge, LA
Feb 6, 2008
  • Feb 6, 2008
How'd ya setup the valves/rockers?
Billy8380
68
  • Feb 6, 2008
Yeah it just dies and and like I am at red line
Billy8380
68
  • Feb 6, 2008
I set each piston at TDC and tightened the rockers down, got the onfi from the crane website
Billy8380
68
  • Feb 6, 2008
I have checked my timing with a timing light and withe the lead on number 1 wire I show to be 14degrees advance but My idle didn't seem to go up when I moved the dist.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 6, 2008
  • Feb 6, 2008
If you are still using OEM springs
There is a possibility the cam is now working the springs harder and they just
don't have enough beens to do the job correctly
Grady
Billy8380
68
  • Feb 6, 2008
The guy I bought the heads from said he replaced the springs when he had the heads worked and he was running an E cam
Grady
gcomfx.com
3,690
Republic, MO
Feb 7, 2008
  • Feb 7, 2008
Two questions.
First is it an AODE car? If so, the rev limiter is NOT set at 7K as one person suggests. It's not even 6K. Thus why most of us chip around the rev limiter in our tunes.
2nd, are you basing this on a stock tach? As they have been known to be off... a LOT on some cars.
Billy8380
68
#10
  • Feb 7, 2008
  • #10
yes to both questions. I was just going by based on my stack setup my tach pulled up to 6k with me manual shifting and now the 5200
gcomfx.com said:
Two questions.
gcomfx.com
3,690
Republic, MO
Feb 7, 2008
#11
  • Feb 7, 2008
  • #11
Found a post Wes made:
"Autos optioned with 2.73 gears (W4H0), the rev limit is 5700
Autos optioned with 3.27 gears (U4P0), the rev limit is 5800"
Your tach could easily be off this much. How you ever made it to 6,000 before this swap. I have no idea, unless your tach was off, or you had a chip installed.
Anyway, the others in this thread could be 100% correct and it's a spring issue. I just wanted to correct a few things in the thread. Get more information for everyone. So hopefully we can get you a quicker and more accurate answer.
Billy8380
68
#12
  • Feb 7, 2008
  • #12
Mine is the W4HO option it may have been the 5700 I just knew it was closer to 6k and now at the 52-53 range I am going to pull my dist but timing looks to be acurate from the timing light.
Any one have ideas on why my idle didn't rise and lower when I adjusted my timing advance or retard?
gcomfx.com
3,690
Republic, MO
Feb 7, 2008
#13
  • Feb 7, 2008
  • #13
Pill in or out?
Billy8380
68
#14
  • Feb 7, 2008
  • #14
out
C
Fuse help please. 73 Mach 1
  • Curtis Harper
  • Oct 19, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 28, 2026
Curtis Harper
C
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Repainting whole vehicle
  • fredpinto
  • Oct 18, 2026
G
Help! 93 Mustang 2.3L A4LD dies at idle
  • goofyfoot53
  • Nov 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2025
goofyfoot53
G
