Is it possible to not drive *enough*?
Drew0318
115
Chicago, IL
Reason I ask, I've got a '99 with 17000 miles on it. I drove it approx 1000 miles this year and now it's sitting under a blanket in a heated garage for probably another 4 months...
I've already replaced a couple pulleys (upper idler/tensioner). Is it a reasonable worry that non-use could contribute to other bits degrading? If so, which ones in particular?
I wish winter would hurry up and die already.
just make sure you take the proper precautions such as fuel savor, full synthetic oil changed every so often (I would say at least twice a year). I have a 2000 GT that I have only put 1000 miles on in the last 3 years total and it still starts and drives like a champ.
Seals around any rotating parts like the engine mains, trans shafts, pinion seal can start to dry out and leak eventually if it sat long enough without ever being driven. O-rings on A/C lines eventually can do the same....
I still have the original battery in my '01...never had a charger or battery tender on it...its got 35K on it.
