Is it running hot or not?
  • Thread starter Thread starter Stever89
  • Start date Start date Oct 26, 2010
Stever89
5 Year Member
Dec 14, 2009
536
9
39
Biloxi, MS
Oct 26, 2010
  • Oct 26, 2010
Let me try to sum this up with the least amount of cunfusion:
I got my coupe last December. At that time it used the factory coolant temp gauge (seemed to work fine). Later, I installed an aftermarket mechanical temp gauge, seemed to work fine too, reading 190.
I installed a fan controller two weeks ago, all's good.
This past week, I took the water temp gauge out and replaced it with another mechanical Jegs gauge to go in my gauge cage in the AC vent. It went to 240! Freaked me out. It didn't seem to be that hot, when a motor gets to 240+, things start smelling and smoking, none of that. I took the tstat housing off to check the tstat, there wasn't one! So I put in a good (checked it in a pot of water) 180 stat. Still went to 240 with the jegs gauge.
So I reinstall the first gauge, just mounted it temporarily under the hood and ran it up to the cowl, it reads 190 like it always did.
So I get a pot of water, put it on the stove and heat it to boiling, and with a known calibrated thermometer, I (carefully) take it outside and put both mechanical temp gauge probe ends in. They both read ~200F, which is good
So both gauges seem to be working accurately when submerged in a pot of hot water, but the jegs gauge goes nuts when it's installed in the manifold.
I know this is confusing, but is there some trick or something I'm missing in the installation of the Jegs probe? I see it has a rubber o ring, the first one did not.
Any suggestions advice is welcome.
2000xp8
SN Certified Technician
Aug 8, 2003
8,061
1,647
194
NJ
Oct 26, 2010
  • Oct 26, 2010
Where do you have the thermometer end screwed into?
Stever89
5 Year Member
Dec 14, 2009
536
9
39
Biloxi, MS
Oct 26, 2010
  • Oct 26, 2010
Into the top of what most of you call the lower intake (this is a carbed 302), driver's side front.
Stever89
5 Year Member
Dec 14, 2009
536
9
39
Biloxi, MS
Oct 26, 2010
  • Oct 26, 2010
Here's one thing I'm gonna do:
I'll run the factory sending unit into the fitting on the tstat neck. At least I'll have 2 sources of data now.
HISSIN50
34
129
Oct 26, 2010
  • Oct 26, 2010
Just remember that the sender in the water neck will function contingent upon the t-stat opening.
What's different in the scenarios when you're running the guage in the cowl vs on the interior?
clement
1,104
52
59
Oak Cliff
Oct 27, 2010
  • Oct 27, 2010
is the sending unit correct?
Stever89
5 Year Member
Dec 14, 2009
536
9
39
Biloxi, MS
Oct 27, 2010
  • Oct 27, 2010
No difference, I'm unscrewing one probe from one mechanical gauge and screwing the other one in it's place.
Stever89
5 Year Member
Dec 14, 2009
536
9
39
Biloxi, MS
Oct 27, 2010
  • Oct 27, 2010
Good question. There are different sending units? You mean different temp ranges? Sorry for ignorance, I'm learning as I go.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Progress Thread Sask84gt's 84 GT - Questions and Progress Thread
  • Sask84gt
  • Oct 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
Sask84gt
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
  • dan50
  • Jul 18, 2026
dan50
