Is it safe to drive my car like this???
Saleen311
67
Hampton, Va
I have an exhaust leak after the exhaust manifold on the passenger side because on of the studs are stripped. I couldnt get the o/r x on tight enough. The check engine light is on but I have MIL eliminators. Is this because of back pressure or is it the first O2 sensors picking this up? My plan is to just put shorty headers on it which wont done until like 2 weeks from now because I havent ordered them yet. Is it safe to drive until I get the headers on?
I won't suggest it if at all possible. Your front o2's are reading. Odds are that is the code.
Some believe you can damage an engine with an exhaust leak so close. ( pulling in cold air into hot combustion chamber)
Things to try to fix the problem.
1. replace the doghnut gasket on passenger side.
2. put some washers under the nut so they are what is pulling the pipe in. thereby hopefully allowing you to fully tighten pipe.
OH MY GOD. Why didnt I think of that?????? Thank you.
