if i port the stock heads is it worth it? how much of gain do you think i would get? Also how much would it run?
Hissing Cobra said:If you use a pair of '69-'70 351W heads and port/polish/install larger valves, you can make over 300 rear wheel horsepower with the right cam, intake, and exhaust. However, the work involved and the labor rate that would be charged would not make it cost effective to go this route. I looked into this thoroughly and decided to go with the AFR 185's instead because it wasn't that much cheaper. Anyway you look at it, good power will cost you. It's just a matter of where you want to spend your money that's important.
Curse said:I know there are some people doing amazing things with ported E7s, but I still say it is not worth it. I went the ported head route and I regret it everyday I look at my dyno reading. I could have had a 300 rwhp car instead of a 250 rwhp car.
Swapping the heads is such a huge project that in my opinion its a waste of time and $$$ to put the stock iron stuff back on. E7's belong in the scrap yard! If you dont have the cash now, save a little longer and do it right, becuase a month after you put ported stockers on you'll start planning to upgrade the heads again! And the answer is our very own Thumper460
Yep, he has been around a long time. I thin his heads or powerheads are a great step up from stock and they will out flow quite a few set of heads that cost almost twice as much. Of course when you decide to port those heads the e7s won't be able to keep up.jackchan said:I had no idea that this guy was part of stangnet?
Unless another $600 pops up some where I plan on getting thumpers. I think this a great bang for buck option. And I don't think this will be something I will be wanting to upgrade again for a long time unlike said above. My car isn't going to be just a track car either. It will be more of my DD. Ported cobra intake with thumpers will be more than enough for me. But, like I said if I could afford the AFR 165s I would get them. Thumpers are a great alternative
jackchan said:I have no clue as to why someone wouldnt think with ported, valve jobbed E7's and a power adder that couldnt be accomplished! Jack
payupsucka said:stock heads will never beat aftermarket heads, even if you put the aftermarket heads on and dont like them you can always port them for even more power i dont think it really worth spending the money to port stock heads when for a little more you can get aluminum heads that are better lighter and will dissapate heat easier every thing that a stock head will never do
AFR165's blow 99% of stock ported heads out of the water!! All comes down to how much you wanna spend and how much power you want out of your motor
Because when I go out and walk all over guys with big heads, high lift cams and such, it feels soo good! Sure my car could be faster, but Id rather have it be impressive!
