I let my car sit outside for about 9 months with the motor apart down to the block, hood closed and a sheet over the block...is my block ruined now? This is what it lookes like.
fox racer said:i dont see why, unless you messed up the rings. then you just get it bored/honed new pistons/rings and say hello to a 306. otherwise just chase those headbolt holes and youll be fine. and clean up the deck.
308Rick 91GT said:With that much rust on the cylinders it would be best to hone it or the rings may not seal, clean it all, have it tanked, decked and do a minor rebuild.
Now since it was sitting the rigs may be seized to the cylinder walls, I'd soak it for a few days before trying to turn it over.
like SOS pads would do. After getting all the rust off I always clean the gasket surfaces with brake cleaner, just spray some on a rag and wipe her down and will get rid of all the grease and junk. Chasing the threads sounds like a good idea too
